Wired Intelligent Edge
  • 1.  Artuba 8320 CX and OID / MIBS
    Posted Apr 20, 2023 09:35 AM
    Hi averyone.
    I need to gather the througput needed to perfom inter-vlan routing on a couple of Aruba 8320 switches.
    Is there a MIB / OID i can monitor to get this information?
    I need to know how much Kbps are routed from a VLAN to another by the switches.
    Thank you.
  • 2.  RE: Artuba 8320 CX and OID / MIBS
    Posted Apr 21, 2023 03:47 AM
    I'm interested too (or, alternatively, a NAE Script to monitor that type of inter-VLAN routed traffic).
  • 3.  RE: Artuba 8320 CX and OID / MIBS
    Posted Apr 23, 2023 04:40 AM
    Hi.
    As Parnassus also say, you can use Network Analytics Engine (NAE) to do a lot of things or the switch is fully managable with REST API.
    SNMP is mostly for 3rd party support.
    Perhaps you can use this guide ?
    https://www.arubanetworks.com/techdocs/AOS-CX/10.08/HTML/snmp_mib/Content/home.htm
  • 4.  RE: Artuba 8320 CX and OID / MIBS
    Posted Apr 23, 2023 06:38 AM
    To be honest, if I remember correctly, initially (some years ago) I was looking for a NAE Script to easily measure the in/out traffic crossing a particular VSX LAG (Multi-Chassis LAG) - I admit I never tried to develop it myself (shame on me!) - and that's to understand any potential "traffic biasing" while traversing (in/out) the VSX Cluster from/to a dual homed peer BUT also looking for a NAE Script to measure inter-VLAN routed traffic would be very useful IMHO...
  • 5.  RE: Artuba 8320 CX and OID / MIBS
    Posted Apr 23, 2023 06:44 AM
    I do not have the time to look into this interesting topic for the time being. Would definitaly be nice to be able to see this.
    Did any of you try to look for something like this on Aruba Solution Exchange (ASE) ?
    https://ase.arubanetworks.com/
  • 6.  RE: Artuba 8320 CX and OID / MIBS
    Posted Apr 26, 2023 10:13 AM
    I looked in the ASE, but didn't find anything in this way. Maybe it's a fault o' mine.
    So, there is no MIB/OID with wich we can gather the VLAN throughput? It's a litte annoying...
