this is a reasonable explanation. I have also discussed this with one of my storage colleagues, even certain SAN switches are able to reach very high RPM values running at 100% speed.
The point is, I'm not worried anymore.
Miro.
Original Message:
Sent: Apr 17, 2025 07:51 AM
Subject: Aruba 10000 max Fan Speeds
Hi! if the output of show environment fan command isn't showing you anything abnormal (thus all ready) and Fan LED status are Green then those speeds - despite quite high if compared to what we could be normally used to - could be reasonable or "by design" for normal operating condition in a correctly cooled datacenter [*] Did you eventually check if - maybe - there is anything related to Fan Modules on Aruba CX 10.13.1090 for Aruba CX 10000?
Edit: to be honest I checked on Aruba CX 8360 with Fans reporting "slow" speed and the RPMs are about 6.6k/7k (downstream/upstream)...so maybe Aruba CX 10000 uses quite different Fan Units or the environment it is running on is warmer (and so Fans need to push more to cool)...could it be?
[*] I wrote that looking at technical data of a Fan Module I know - made of an upstream fan tied in series to a downstream fan, so two fans coupled in a single Fan unit Port-to-Power (the reverse in case of Power-to-Port) - of a similar Aruba CX 8360 switch...I then see 20k/23k RPMs on normal operation with che upstream fan pushing 3k RPMs more than the downstream one...so, comparing with your values, if Aruba CX 100000 Fans Units are similar to ones used by Aruba CX 8360 then they are not running exactly at their maximum possible RPMs (18/20k vs 20/23k RPMs). Something like this.
Original Message:
Sent: Apr 16, 2025 12:19 PM
running DL.10.13.1060 (Aruba CX 10000-48Y6C) we see quite high values for Fan speeds, i.e. from one switch today:
Fan information
Location- Product Serial Number Speed Direction Status RPM
Mbr/Slot/Fan Name
PSU-1/1/1 N/A N/A N/A back-to-front ok 5640
PSU-1/2/1 N/A N/A N/A back-to-front ok 5728
Tray-1/1/1 N/A N/A normal back-to-front ok 20849
Tray-1/1/2 N/A N/A normal back-to-front ok 18060
Tray-1/2/1 N/A N/A normal back-to-front ok 20849
Tray-1/2/2 N/A N/A normal back-to-front ok 17880
Tray-1/3/1 N/A N/A normal back-to-front ok 20849
Tray-1/3/2 N/A N/A normal back-to-front ok 18120
Tray-1/4/1 N/A N/A normal back-to-front ok 21093
Tray-1/4/2 N/A N/A normal back-to-front ok 18120
Tray-1/5/1 N/A N/A normal back-to-front ok 21011
Tray-1/5/2 N/A N/A normal back-to-front ok 18060
Tray-1/6/1 N/A N/A normal back-to-front ok 21343
Tray-1/6/2 N/A N/A normal back-to-front ok 18243
Are these real speed values for RPM? It says normal for all trays. Then, what are the maximal numbers we can still accept and not be worried? Are those RPM values realistic, or something is just reported wrongly? They seem to me quite crazy for a "normal" operation in an environmentally well equipped datacenter.
Thx,
Miro.
Miro.
