Please check/ask on the Instant ON forum. The 1930 is a different product line and specific knowledge is available there.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 17, 2025 09:06 AM
Subject: aruba 1930 48G setting
Thanks, is there example config which I can download?
Original Message:
Sent: 2/14/2025 5:18:00 AM
Subject: RE: aruba 1930 48G setting
Go to InstantOn help center for all information you need on InstantOn product line.
InstantOn Documentation Home
Best, Gorazd
Gorazd Kikelj
MVP Guru 2025
Original Message:
Sent: Feb 07, 2025 08:29 AM
Thanks, how to setup the vlan setting, would it be possible to give suggestions?
vlan 1
name 'DEFAULT_VLAN"
untagged 1-52
Original Message:
Sent: 2/5/2025 11:44:00 AM
Unfortunately not
Shpat | ACEP | ACMP | ACCP | ACDP |
-Just an Aruba enthusiast and contributor by cases
Original Message:
Sent: Feb 05, 2025 06:41 AM
Would it be possible to use it by command mode? Thanks.
Original Message:
Sent: 2/5/2025 12:02:00 AM
Hi Ektrontek,
The 1930 48G is a InstantON Switch and can be Managed either through GUI or CloudApp (Aruba InstantON AP).
Here is a video on how to setup:
https://www.youtube.com/watch?v=nPkTflJyAUI&themeRefresh=1
and
https://www.youtube.com/watch?v=KWkIygL4MKo
Original Message:
Sent: Feb 04, 2025 11:27 PM
hi,
In previous switch, I can use console to setup switch setting by putty, how can I do the way in aruba 1930 48G device? i don't find console port in the switch.
Thanks.
