Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
Community Home
Discussion
Topic Thread
Wired Intelligent Edge
Community Home
Discussion
39.2K
Library
1K
Events
0
Members
1.9K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
Jump to
This thread has been viewed 19 times
1.
0
Kudos
greg44
Posted Jun 24, 2022 11:38 AM
Reply Privately
Options Dropdown
i would like to know if it's possible to connect a non poe device (standard interface RJ45 from my laptop for exemple) to the POE interface of my aruba 1930?
Thank you.
2.
RE: ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
0
Kudos
MVP GURU
parnassus
Posted Jun 26, 2022 05:39 AM
Reply Privately
Options Dropdown
Yes, it is. What is worrying you about?
Original Message
Original Message:
Sent: Jun 24, 2022 11:37 AM
Subject: ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
Thank you.
3.
0
Kudos
greg44
Posted Jun 30, 2022 04:12 AM
Reply Privately
Options Dropdown
i just would like to knpow the mechanism that's make it safe. :)
Original Message
Original Message:
Sent: Jun 26, 2022 05:38 AM
Original Message:
Thank you.
4.
0
Kudos
MVP GURU
parnassus
Posted Jul 01, 2022 12:00 PM
Reply Privately
Options Dropdown
Since the Aruba 1930 adheres to IEEE Standards and since the
IEEE standard PoE behavior requires that the Switch first checks if there is a PoE capable devices attached to the physical interface, once the switch successfully identified a PoE capable device (which is a PD Powered Device, I add) it supplies power as required by the recognized PD. That's the mechanism that made it safe for non-PD device to be connected to a PoE capable Switch adhering to IEEE Standards.
Original Message
Original Message:
Sent: Jun 30, 2022 04:12 AM
Original Message:
Original Message:
Thank you.
5.
0
Kudos
greg44
Posted Jul 04, 2022 05:01 AM
Reply Privately
Options Dropdown
Ok, thanks you for this precise answer.
Original Message
Original Message:
Sent: Jul 01, 2022 12:00 PM
Original Message:
Original Message:
Original Message:
Thank you.
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
