\InstantOn - Wired (For the Switch) since think there is potentially a misconfiguration somewhere in the Switch, which is covered in the Instant On - Wired section
If you find my comment helpful, KUDOS are appreciated.
Original Message:
Sent: Feb 18, 2025 02:56 PM
Subject: Aruba 1930 vs Cisco
Which one should I choose?
Original Message:
Sent: Feb 18, 2025 02:50 PM
I have multiple network infrastructure containing combinations of Cisco and Aruba InstantON and i have never experienced such issues.
As said, if you seek more information related to Aruba InstantON, the Aruba Airheads is not the right Community to seek detailed answers.
You should check and post on the Aruba InstantON Community, which is: https://community.instant-on.hpe.com/communities/community-home?CommunityKey=561498fa-2e5d-44bf-a6b5-837d92ce0e15
Shpat | ACEP | ACMP | ACCP | ACDP
Just an Aruba enthusiast and contributor by cases
Original Message:
Sent: Feb 18, 2025 02:39 PM
I understand you. however everything works if I put a cisco switch in place of the aruba. I'm trying to get the cisco to talk to the aruba.
I know how to configure from cisco to cisco, but when I put the aruba the AP does not receive the IP of the core and everything seems correctly configured, because I do trunk on port 41 of the cisco that carries the vlnas 50,61 and 62 and then on port 24 of the aruba I do trunk and put the vlnas 50,61 and 62 and even so the AP that is on port 23 does not receive the IP from core. Thats wierd for me
Original Message:
Sent: Feb 18, 2025 02:29 PM
It is hard to troubleshoot a scenario without having proper configuration checkup. Potentially, there might be a missing configuration of a DHCP Helper, or other related issues. What you can try is:
1. Remove the AP Uplink, connect it on a Laptop and try if the laptop is getting DHCP. If yes, then you need to check the InstantON AP Configuration which were previously configured. Maybe you need to perform an AP Factory Reset.
2. If the Laptop is not getting DHCP as well, you need to troubleshoot the whole cascade links.
Original Message:
Sent: Feb 18, 2025 02:23 PM
The configuration you see in the diagram is done, however, my AP doesn´t receive IPs from core. Thas the problem, I know how I can configure Vlans in Instant, but I don´t understand why the IPs don't arrive to AP
Original Message:
Sent: Feb 18, 2025 02:16 PM
Configuring Trunk mode in Aruba 1930 instantON means you need to do the port with Tagged Configuration.
So for Trunk concept in Cisco, you have to configure: Tagged and add the tags 7, 50, 61, 62
For Access concept in Cisco, you have to configure: Untagged and add the tag 50
A short video on how to configure VLANs in InstantON.
https://www.youtube.com/watch?v=870AHojeYOQ
Original Message:
Sent: Feb 18, 2025 01:51 PM
Thats my diagram
Original Message:
Sent: Feb 18, 2025 01:38 PM
Aruba InstantON Community portal where you can address questions/require assistance and ideas is:
However, which VLAN do you want to have on the Aruba InstantON Switch?
Original Message:
Sent: Feb 18, 2025 01:27 PM
ok, understood. however, do you have any tips to help me?
Original Message:
Sent: Feb 18, 2025 01:14 PM
To make it more simple: untagged port is equivalent to an access port on a Cisco switch
Original Message:
Sent: Feb 18, 2025 11:59 AM
Untagged means no trunk ?
Original Message:
Sent: 2/18/2025 11:44:00 AM
Subject: RE: Aruba 1930 vs Cisco
Aruba InstantON isa different productline and the Support Community page is under this link
Also, in Aruba InstantON you need to configure the port as untagged and the VLAN you want the AP to be placed.
Original Message:
Sent: Feb 18, 2025 09:50 AM
Hi Folks
I work with cisco switches connecting in AP Aruba 228 and 225 thro Instant system. Works fine
Due a project of security cameras, I need to conect cisco switch with new Aruba instant on 1930 swicth 24ports. In this aruba I am trying to connect an AP 228. However even configre vlans, trunk the AP doesn´t work
So, cisco switch can talk with Aruba by ping, but I can´t configure to pass the Vlans across 1930 for AP get IPs.
Could you help me how can I do this configuration?
Let me know if you need more details
Thank you in advance
Wilson
