Comware
Aruba 2530-24G rate-limit not working
  • 1.  Aruba 2530-24G rate-limit not working
    Posted Nov 26, 2024 07:47 AM
    I have a Aruba 2530-24G switch where i try to enable rate-limit, and i cant get it to work.
    I.e im running the command (under the interface):
    int 20 rate-limit all in kbps 210000
    Which applies and shows. But i also want to do this on OUTGOING traffic.
    In the manual it says:
    int <port-list> rate-limit all <in|out> percent <0-100>|kbps <0-100000000>>
    However if i enter:
    int 20 rate-limit all out kbps 210000
    i get the error:
    Invalid input: out
    Anyone have any ideas on why not outgoing rate-limit is working?
  • 2.  RE: Aruba 2530-24G rate-limit not working
    Posted Nov 27, 2024 01:15 AM
    2530 is ArubaOS-S (procurve) platform. Maybe you will have more luck in wired forum than on comware.
    I have this switch available and can test.
    Best,Gorazd
    Gorazd Kikelj
    MVP Guru 2024
