Comware
Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
This thread has been viewed 59 times
  • 1.  Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
    Posted 13 days ago
    HI,
    I've been installing more than 10 updates for two 2530 switches before, always downloading .swi firmware updates from the Aruba support pages. All happened as expected. Now I'm trying to install the YA_16_11_0019 and I get an error upon upload (failed, not a valid signature).. This happens for both switches. I installed the YA_16_11_0018 a few minutes before, and everything was OK as usual. I tried a second download from a different PC and OS (macOS 13) and it goes the same way.
    Any idea what I'm doing wrong ?
  • 2.  RE: Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
    Posted 12 days ago
    We're seeing the same issue, we have reported it to HPE support team. awaiting an update.
  • 3.  RE: Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
    Posted yesterday
    Same here, ticket opened. I'm surprised that this got past testing and into the wild.
  • 4.  RE: Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
    Posted yesterday
    I am seeing the same issue, I just tried 16_11_0020 and getting the same result.
  • 5.  RE: Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
    Posted yesterday
    I got a reply that TFTP should be used to install these updates, though I have not tested yet. I hope it helps someone!
    TFTP procedure: https://www.arubanetworks.com/techdocs/AOS-S/16.11/MCG/WC/content/common%20files/usi-tft-dow-sof-ser.htm
  • 6.  RE: Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
    Posted 12 hours ago
    Same problem for both the YA_16_11_0019 version and the YA_16_11_0020 version.
    I confirm that I solved the problem and was able to upgrade the firmware via TFTP.
    Best Regards
  • 7.  RE: Aruba 2530 switch firmware update YA_16_11_0019 upload failed - not a valid signature
    Posted 12 hours ago
    I confirm that the update via TFTP works correctly for both version YA_16_11_0019 and version YA_16_11_0020.
    Regards
