Wired Intelligent Edge
Aruba 2930F-48G-4SFP Switch (JL260A) ERR 10110060
  • 1.  Aruba 2930F-48G-4SFP Switch (JL260A) ERR 10110060
    Posted Sep 01, 2021 10:49 AM
    Hi all,
    can you please help me with the error on my Aruba 2930F-48G-4SFP Switch (JL260A).
    Primary Software WC.16.10.0016
    Secondary Software WC.16.10.0016 (Booted)
    ROM WC.16.01.0008
    I have warning massage - port XX self test failure ERR: 10110060
    Unfortunately I could not find any information on this error code.
    Pavel Lopushansky
  • 2.  RE: Aruba 2930F-48G-4SFP Switch (JL260A) ERR 10110060
    Posted Sep 01, 2021 06:18 PM
    Edited by parnassus Sep 01, 2021 06:21 PM
    Hi Pavel, if the switch performs the boot process correctly using the WC.16.10.0016 from the Secondary Software Image and then you recognize just one (or few) physical ports with the reported self test failure message, I suggest you to grab the whole output of the show tech all CLI command and then contact Aruba by opening a Support Ticket (via the Aruba ASP). Probably your switch is faulty if it is capable to boot flawlessly (otherwise try to boot from the Primary Software image if the booted one is corrupt).
    See also here, note the suggestion: "If the switch will boot, gather a "show tech all" and review the logs to see what error is reported in the event log. These normally coincide with the fault LEDs on the switch. Use this data to determine what is causing the failure."
    BUT...I found this on a old Release Notes:
    You didn't tell us the involved port is equipped with a Transceiver (unsupported?).
    Please report the output of show tech transceivers too.
    Davide Poletto
  • 3.  RE: Aruba 2930F-48G-4SFP Switch (JL260A) ERR 10110060
    Posted Sep 06, 2021 06:39 AM
    Hi Davide! We was contacted Aruba support and decided to replace this switch under warranty.
    Thanks for you answer, the discussions be closed.
    Pavel Lopushansky
