Wired Intelligent Edge
  • 1.  Aruba 2930f dhcp-snooping
    Posted Dec 31, 2020 08:21 AM
    Hi
    I had configured dhcp-snooping on my aruba 2930f switches like this:
    dhcp-snooping
    dhcp-snooping vlan 1-1000
    inter trk1
          dhcp-snooping trust
    after run these lines the computers can't get dynamic-ip from the server.
    The 2930f version is WC.16.10.0007
    Ronel
    Ronel Shahakui
  • 2.  RE: Aruba 2930f dhcp-snooping
    Posted Dec 31, 2020 12:54 PM
    Have you considered to add dhcp-snooping authorized-server <ip-address-of-dhcp-server> command too? I mean you enabled DHCP Snooping on VLAN Id 1-1000 range and you trusted the trk1 interface where the DHCP Server is supposed to be reached through...this is OK but how was then configured the Switch where the DHCP server is directly connected to (if any)? is the IP Helper Address properly configured on each of your various VLANs (if/where required)?
    Davide Poletto
  • 3.  RE: Aruba 2930f dhcp-snooping
    Posted Dec 31, 2020 01:23 PM
    Edited by Ronelsh Jan 03, 2021 02:27 AM
    The trk1 connect to catalyst 6500 who is the layer3 of the vlans.
    Each interface vlan have an ip helper to the DHCP.
    When I disabled the snooping, it's all working fine.
  • 4.  RE: Aruba 2930f dhcp-snooping
    Posted Dec 31, 2020 01:41 PM
    On the Aruba 2930F can you post the output of these two commands:
    show dhcp-snooping
    show dhcp-snooping binding
    Davide Poletto
  • 5.  RE: Aruba 2930f dhcp-snooping
    Posted Jan 03, 2021 02:37 AM
    Edited by Ronelsh Jan 03, 2021 06:47 AM
    We have able to solve the problem:
    Because on Nexus option 82 was disabled
    "Insertion of Option 82 is disabled"
    We had to disable the option on the Aruba too
    "no dhcp-snoop option 82"
    Ronel Shahakui
  • 6.  RE: Aruba 2930f dhcp-snooping
    Posted Nov 08, 2021 11:49 AM
    Dear Parnassus
    I wish you being well
    Please i need to enable the dhcp-snooping based on the attached topology, so i need to know the used commands and the right sequence to start
    Muhammad Zakariya
    Attachment(s)
    pdf
    Drawing1.pdf   135 KB 1 version
  • 7.  RE: Aruba 2930f dhcp-snooping
    Posted Nov 09, 2021 01:11 AM
    Hi
    global config:
    dhcp-snooping
    dhcp-snooping vlan (vlans numbers)
    on each port that forward the packet (interface 25) you need to config
    dhcp-snooping trust
    Ronel Shahakui
