Wired Intelligent Edge
Aruba 2930f (jl262a) and IP routing
  • 1.  Aruba 2930f (jl262a) and IP routing
    Posted Jul 30, 2019 09:06 PM
    Hi All,
    After reviewing a number of posts - i am a little stumped on the assignment of IP to a trk1 group
    - the extended site is MPLS back to a data centre
    - replacing a old switch at a remote site
    - I have created a trunk (TRK1 and only added port1) and tagged the trk1 into the 2x vlan interfaces
    - The vlan interfaces have their required physical orts assigned as untagged.
    - the IP to be assigned is a non-routable IP  (think 192.168.1.x)
    - i have enabled "ip routing" and yet to add the outbound routes to the attached config
    My Outcome is to assign a mpls provided IP to the trunk, and have the subnets route out via the trunk. The switch will be opertaing as layer3 and do the intervlan routing.
    - if the approach of the trk1 group is incorrect then advise.
    - any url links to aruba knownledge base article is welcome
    I have attached my config
    Thoughts?
    Wayne
    Attachment(s)
  • 2.  RE: Aruba 2930f (jl262a) and IP routing
    Posted Jul 31, 2019 02:19 AM
    You cannot add an ip adress to a port (routed interface).
    You can add an ip adress to a vlan, and tag that vlan to a trunk, like you did.
    Couple of questions:
    You added physical port 1 to TRK1, is that correct? is port 1 the physical connection to your upstream router? TRK1 should include the physical ports.
    I see TRK1 is not using LACP, is that correct?
    Is the other site of the TRK1 interface using vlan tagging as well?
    Don't forget to add a default route.
