Developer
  • 1.  Aruba 2930F Management
    Posted 22 days ago
    I have several Aruba switches including 3810M and 2930F. I went to configure management network for the switches including 3810M using oobm port and also for 2930F using defined management-vlan. When I try to add 3rd 2930F to management network, configuration went fine but I can not ping it nor access it with SSH. I tried another 2930F switch, but same issue. Anyone had same issue?
    Kind regards.
  • 2.  RE: Aruba 2930F Management
    Posted 19 days ago
    Configuring the management VLAN statement in 2930F can be a bit confusing. Check this post if that may be the same in your case.
    " If you set a management-vlan that vlan is not routed, and is only accessible by other devices on that vlan. It's designed to mimic the behavior of a physical oobm port.
    It sounds like that's not the actual desire here [NOTE: This is in the original message], so just get rid of the management-vlan statement.  You can lock it down as necessary using "ip authorized-managers" statements (switch management ACLs)"
