Hi akg7
Yes I think its something on ther server as well, but I can't figure out why. I tried every which way as advised on several different guides, but I still get the same error on the event viewer. Can't find any standard guides just for aruba however, so maybe there is something I'm missing. Is there something I can follow to try again?
Below are the results from the commands. (replaced the ips and user names)
Status and Counters - Authentication Information
Authorized enabled as backup for secondary login are preceded by *
Login Attempts : 3
Lockout Delay : 0
Respect Privilege : Enabled
Bypass Username For Operator and Manager Access : Disabled
| Login Login Login
Access Task | Primary Server Group Secondary
Console | Local None
Telnet | Local None
Port-Access | EapRadius radius None
Webui | Local None
SSH | Radius radius Local
Web-Auth | ChapRadius radius None
MAC-Auth | ChapRadius radius None
SNMP | Local None
Local-MAC-Auth | Local radius None
REST | Radius Local
| Enable Enable Enable
Telnet | Local None
Webui | Local None
REST | Radius None
Status and Counters - General RADIUS Information
Dead RADIUS server are preceded by *
Deadtime (minutes) : 0 TLS Dead Time (minutes) : 0
Timeout (seconds) : 5 TLS Timeout (seconds) : 30
Retransmit Attempts : 3 TLS Connection Timeout (seconds) : 30
Global Encryption Key :
Dynamic Authorization UDP Port : 3799
Source IP Selection : Outgoing Interface
Source IPv6 Selection : Outgoing Interface
Tracking : Disabled
Request Packet Count : 3
Track Dead Servers Only : Disabled
Tracking Period (seconds) : 300
ClearPass Identity :
Auth Acct DM/ Time |
Server IP Addr Port Port CoA Window | Encryption Key OOBM
1.1.1.1 1812 1813 No 300 | xxxxxxx No
Image stamp: /ws/swbuildm/rel_ajanta_qaoff/code/build/lvm(swbuildm_rel_ajanta_qaoff_rel_ajanta)
Jun 7 2021 21:35:47
WC.16.10.0015
516
Boot Image: Primary
Boot ROM Version: WC.16.01.0008
Active Boot ROM: Primary
W 08/24/21 13:13:33 00419 auth: Invalid user name/password on SSH session User
'luser' is trying to login from 1.1.1.1
I 08/24/21 13:08:11 04694 auth: Authentication and authorization are configured
with the same method.Command authorization will be performed for all
SSH users.
W 08/24/21 13:07:51 04693 auth: Authentication and authorization are configured
with different methods. Command authorization may be skipped for
some SSH users.
W 08/24/21 13:07:11 04693 auth: Authentication and authorization are configured
some SSH users.
W 08/24/21 13:07:04 04693 auth: Authentication and authorization are configured
some SSH users.
W 08/24/21 13:04:13 00419 auth: Invalid user name/password on SSH session User
'user' is trying to login from1.1.1.1
W 08/24/21 13:03:36 00419 auth: Invalid user name/password on SSH session User
'user' is trying to login from 11.1.1.1
I 08/24/21 12:49:40 03363 auth: User 'user' logged out of SSH session from
1.1.1.1
W 08/24/21 12:49:40 00641 ssh: read error Operation timed out, session aborted
W 08/24/21 10:59:33 00419 auth: Invalid user name/password on SSH session User
'user' is trying to login from 1.1.1.1
W 08/24/21 10:45:46 00419 auth: Invalid user name/password on SSH session User
W 08/24/21 10:45:05 00419 auth: Invalid user name/password on SSH session User
'user is trying to login from 1.1.1.1
