Skip main navigation (Press Enter).
Log in
Toggle navigation
Search Options
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
HPE Aruba Networking Central Status
Live + Virtual Events
Webinar Archive
Upcoming Events
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Search Options
Network Management
Community Home
Discussion
22.8K
Members
1.6K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Aruba 2930F SFP to RJ45 adapter
This thread has been viewed 34 times
t.antony
Dec 13, 2022 02:24 PM
I need to convert SFP to RJ45 so I can connect ethernet to a port on the 2930F 24 port switch. Just to ...
t.antony
Dec 13, 2022 02:30 PM
Because the official Aruba ones are way more expensive, so I just want to make sure the Cable Matters ...
t.antony
Dec 13, 2022 03:08 PM
Actually, the Cable Matters one says this, so if its not compitable with HP, that means Aruba also ...
t.antony
Dec 13, 2022 03:15 PM
This should work? J8177D HPE Aruba Compatible 1000BASE-T SFP Copper RJ-45 100m Transceiver Module ...
parnassus
Dec 13, 2022 08:21 PM
A non genuine J8177D (3rd Party) Transceiver could work provided that you allow unsupported transceivers ...
dghjfsg
Dec 14, 2022 02:43 AM
Good morning, we use tranceivers from Optical Networking Solutions Supplier | Solid Optics (solid-optics.com) ...
t.antony
Dec 14, 2022 08:41 AM
Thank you everyone------------------------------------------- Original Message: Sent: Dec 14, 2022 ...
t.antony
Dec 16, 2022 03:32 PM
So I found an unused port on the switch, so I don't even need this transceiver now. But, if I did ...
parnassus
Dec 16, 2022 06:51 PM
Yes, that command allows the Switch to support 3rd Party Transceivers. ------------------------------------------- ...
1.
0
Kudos
t.antony
MVP
Posted Dec 13, 2022 02:24 PM
Reply Privately
Options Dropdown
Just to make sure, I can use this right?
https://www.amazon.com/Cable-Matters-1000BASE-T-Transceiver-Supermicro/dp/B07TXRYJGF
2.
RE: Aruba 2930F SFP to RJ45 adapter
0
Kudos
t.antony
MVP
Posted Dec 13, 2022 02:30 PM
Reply Privately
Options Dropdown
Because the official Aruba ones are way more expensive, so I just want to make sure the Cable Matters one works also.
https://www.amazon.com/HP-Aruba-RJ45-Cat5e-Transceiver/dp/B0796BX47F
Original Message
Original Message:
Sent: Dec 13, 2022 02:23 PM
Subject: Aruba 2930F SFP to RJ45 adapter
3.
0
Kudos
t.antony
MVP
Posted Dec 13, 2022 03:08 PM
Reply Privately
Options Dropdown
Actually, the Cable Matters one says this, so if its not compitable with HP, that means Aruba also right?
NOT compatible with Dell Networking / Juniper / Mellanox /
HP
/ H3C / Arista / Dell Force10 / Extreme / F5 / Mikrotik Networks equipment
Original Message
Original Message:
Sent: Dec 13, 2022 02:30 PM
Original Message:
4.
0
Kudos
t.antony
MVP
Posted Dec 13, 2022 03:15 PM
Reply Privately
Options Dropdown
This should work?
J8177D HPE Aruba Compatible 1000BASE-T SFP Copper RJ-45 100m Transceiver Module for HPE Aruba Switch Series
According to this parts list for 2930F .
Aruba 2930F Switch Series - Option Parts
Original Message
Original Message:
Sent: Dec 13, 2022 03:07 PM
HP
Original Message:
Original Message:
5.
0
Kudos
parnassus
MVP EXPERT
Posted Dec 13, 2022 08:21 PM
Reply Privately
Options Dropdown
provided that
you allow unsupported transceivers first with the proper command (I doubt a FS Transceiver will be recognized as an original Aruba one, it will most probably labelled as "unsupported" / "third party" and the allowing unsupported transceivers should be the only way to try it with no warranty at all...being not genuine HPE/Aruba).
Original Message
Original Message:
Sent: Dec 13, 2022 03:14 PM
This should work?
Original Message:
HP
Original Message:
Original Message:
6.
0
Kudos
dghjfsg
Posted Dec 14, 2022 02:43 AM
Reply Privately
Options Dropdown
these work very wel on the 2930F. We use the optical and copper ones. Never had a problem with them. The fun part of these optical trancievers are that they are reprogrammable. I you want to use the copper (RJ45) tranceivers for Aruba, then they are specially programmed by Solid optics. If you program them to for example Cisco or Juniper, you can not program them yourself back to Aruba.
Original Message
Original Message:
7.
0
Kudos
t.antony
MVP
Posted Dec 14, 2022 08:41 AM
Reply Privately
Options Dropdown
Thank you everyone
Original Message
Original Message:
Sent: Dec 14, 2022 02:42 AM
Original Message:
8.
0
Kudos
t.antony
MVP
Posted Dec 16, 2022 03:32 PM
Reply Privately
Options Dropdown
But, if I did have an un-official 3rd party transceiver, I need to enable it using the command below?
https://www.arubanetworks.com/techdocs/AOS-CX/10.08/HTML/fundamentals_4100i-6000-6100/Content/Chp_IfaceCfg/Iface_cmds/all-uns-tra.htm
Original Message
Original Message:
Sent: Dec 14, 2022 08:41 AM
Thank you everyone
Original Message:
Original Message:
9.
0
Kudos
parnassus
MVP EXPERT
Posted Dec 16, 2022 06:51 PM
Reply Privately
Options Dropdown
Original Message
Original Message:
Sent: 12/16/2022 3:32:00 PM
Subject: RE: Aruba 2930F SFP to RJ45 adapter
Original Message:
Thank you everyone
Original Message:
Original Message:
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
Aruba compatible SFP
t.antony
Added Sep 05, 2023
Discussion Thread
15
FCS errors on fiber transceiver
t.antony
Added Nov 22, 2024
Discussion Thread
11
VoIP phones PoE, 2930F
t.antony
Added Feb 14, 2023
Discussion Thread
10
Aruba 2930f Voice VLAN
t.antony
Added Jul 21, 2022
Discussion Thread
6
Can't upgrade firmware on 2930F switches
t.antony
Added Jul 23, 2024
Discussion Thread
8
Copyright 2024. All rights reserved.
Powered by Higher Logic
