Wired Intelligent Edge
ARUBA 2930M 24G -High collision or drop rate on ports with cameras
  • 1.  ARUBA 2930M 24G -High collision or drop rate on ports with cameras
    Posted Aug 04, 2020 06:45 PM
    Hello guys,
    This is my first post in a forum in my entire life,so sorry if I miss some information or important description.
    The following happens to me:
    I have installed 4 switches (stacking), in unit 4 there are 24 cameras connected, the show logging command shows me the following log's:
    W 07/30/20 17:05:11 00331 FFI: ST1-CMDR: port 4/1-High collision or drop rate.
                See help.
    W 07/30/20 17:05:11 00331 FFI: ST1-CMDR: port 4/6-High collision or drop rate.
                See help.
    W 07/30/20 17:05:11 00331 FFI: ST1-CMDR: port 4/7-High collision or drop rate.
                See help.
    W 07/30/20 17:05:11 00331 FFI: ST1-CMDR: port 4/9-High collision or drop rate.
                See help.
    W 07/30/20 17:05:11 00331 FFI: ST1-CMDR: port 4/11-High collision or drop rate.
                See help.
    I would like to know why those ports where the cameras are connected are in a constant High collision or drop rate response. I will attach the "show tech" if its necessary.
    The Switch is a ARUBA 2930M 24G POE+ 1-SLOT SWITCH
    Regards.
    Attachment(s)
    txt
    IDF-1B.txt   5.24 MB 1 version
