No that won't work:
Aruba 250W Power Supply, (JL085A, Aruba X371 250W 100-240VAC to 12VDC PS) is used with the non-
PoE switches and is keyed so that it cannot be used in the PoE/PoE+ switches.
• Aruba 680W PoE+ Power Supply, (JL086A, Aruba X372 680W 100-240VAC to 54VDC PS) used with the
PoE/PoE+ switches and is keyed so that it cannot be used in the non-PoE switches.
• Aruba 1050W PoE+ Power Supply, (JL087A, Aruba X372 1050W 100-240VAC to 54VDC PS) is used with
the PoE/PoE+ switches and is keyed so that it cannot be used in the non-PoE switches
Original Message:
Sent: Apr 24, 2024 11:52 AM
Subject: Aruba 3810M (JL075A) support JL085A + JL087A power supply together
Hello, I'm inquiring about the possibility of utilizing both power supplies simultaneously on the Aruba 3810M
