Network Management
  • 1.  Aruba 3810M stack - Firmware update
    Posted Jan 19, 2022 07:43 AM
    Hi All
    Please I require some advice with updating a Core Stack x4
    Some articles say this can be done via website GUI but my concern is that when doing so with a stacked switch, don't you need to boot system rather for the entire stack to restart ? (CLI)
    Also I have reached out to Aruba support as this current version is old KB 16.07.003, they recommended updating to KB 16.09, run the "Boot-System flash Pri |Sec depending on which image is being updated
    Has anyone done stacking firmware update from the GUI with 3 or more members and thereafter selected boot primary then reboot ? for this model
    Warren Maistry
  • 2.  RE: Aruba 3810M stack - Firmware update
    Posted Jan 19, 2022 10:53 AM
    Yes you can perform this from the WebGUI, and it will reboot the entire stack.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Aruba 3810M stack - Firmware update
    Posted Jan 20, 2022 01:44 AM
    Hi Dustin
    Thank you for the prompt response back, much appreciated
    ddlogo
    Warren Maistry (MEA)
    MS Engineer (L1)
    m. +27 61 2031664 t. +27 11 5756184
    email. warren.maistry@dimensiondata.com
    dimensiondata.com
    ddtwitter
    ddlinkedin
    ddfacebook
    ddinstagram
    Logo
