Wired Intelligent Edge
  • 1.  Aruba 3810M stacking best practices
    Posted Mar 14, 2024 01:38 PM
    Aruba 3810M 16 ports stacking best practices.
    Can i use front Fiber ports for stacking or stacking module is required?
  • 2.  RE: Aruba 3810M stacking best practices
    Posted Mar 15, 2024 08:41 AM
    The 3810M uses stacking modules. No frontplane stacking afaik.
  • 3.  RE: Aruba 3810M stacking best practices
    Posted Mar 15, 2024 09:17 AM
    It is not possible to do stacking (BPS - Backplane Stacking) through fiber ports.
    You will need to add the module JL084A Aruba 3810M 4-port Stacking Module.
    I am attaching the datasheet for more information.
    Regards
    Leonardo Xavier
    Analista de Redes
    hcor
    acma
    Attachment(s)
    pdf
    DS_3810SwitchSeries.pdf   468 KB 1 version
  • 4.  RE: Aruba 3810M stacking best practices
    Posted Mar 15, 2024 03:57 PM
    Yes, a stacking module is required, the 3810M does not support front plan stacking or VSF, as it's called.
    You will require the module and the dedicated stacking cables
  • 5.  RE: Aruba 3810M stacking best practices
    You do require the dedicated module and cables.
  • 6.  RE: Aruba 3810M stacking best practices
    Posted Apr 11, 2024 03:28 AM
    Edited by Steinar Grande Apr 11, 2024 04:30 AM
    Best practice:.. happy stacking :)
    –High-performance stacking provides up to 336 Gbps
    of stacking throughput; each 4-port stacking module
    can support up to 42 Gbps in each direction per
    stacking port
    –Ring, chain, and mesh topologies support up to
    a 10-member ring or chain and 5-member fully
    meshed stacks; meshed topologies offer increased
    resiliency vs. a standard ring
    Steinar
  • 7.  RE: Aruba 3810M stacking best practices
    Posted Apr 11, 2024 04:17 AM
    Manual
    Steinar
  • 8.  RE: Aruba 3810M stacking best practices
    Posted Apr 11, 2024 04:36 AM
    manual part II
    Steinar
    Attachment(s)
