Wired Intelligent Edge
  • 1.  Aruba 5412rzl2 Multicast VLAN routing - IPTV
    Posted Apr 23, 2019 06:44 AM
    I have a core switch setup that needs to route incoming IPTV streams from operator specified IP in VLAN 600 to IPTV VLAN 180 that will later be used to connect TV-s.
    Operator has provided an address to be used on core switch vlan interface 172.20.32.58/30 and gateway 172.20.32.57. I am able to ping vlan interface and gateway from core switch however from vlan 180 with IP 10.55.80.1 I am not able to do so.
    I have also configured multicast on both VLAN's as per instructions in the documentation.
    Probably missing something in the routing department.
    I am attaching the configuration for review.
    I would appreciate any help.
    Thx
    Attachment(s)
    txt
    config.txt   5 KB 1 version
  • 2.  RE: Aruba 5412rzl2 Multicast VLAN routing - IPTV
    Posted Apr 24, 2019 02:14 AM
    Does the IPTV stream supports multicast routing? In most cases the IPTV stream don't support multicast routing.
    You can take a look into the IGMP proxy feature. In this case the switch is a IGMP querier and will proxy the multicast traffic. I'm not a multicast specialist but multicast routing in this case doesn't work I think
  • 3.  RE: Aruba 5412rzl2 Multicast VLAN routing - IPTV
    Posted Apr 24, 2019 05:10 AM
    Did the service provider specifically tell you to run PIM SM?
    In that case, did you form any neighborship?
    "show ip pim neighbor"?
  • 4.  RE: Aruba 5412rzl2 Multicast VLAN routing - IPTV
    Posted Apr 24, 2019 07:32 AM
    Thanks guys.
    Yes they did. Command output as requested:
    XXXXXXXXXX(config)# sh ip pim neighbor
    PIM Neighbors
    IP Address VLAN Up Time (sec) Expire Time (sec)
    172.20.32.57 600 59195 84
  • 5.  RE: Aruba 5412rzl2 Multicast VLAN routing - IPTV
    Posted Apr 24, 2019 07:54 AM
    Okay cool,
    Do you get any output with "show ip mroute"?
  • 6.  RE: Aruba 5412rzl2 Multicast VLAN routing - IPTV
    Posted Apr 24, 2019 02:18 PM
    Again thanks for pointers you guys gave me.
    I was able to get it to work.
    Provider indeed does not support multicast routing. I had to add secondary IP to vlan 180 to get it to work and then setup IGMP proxy as well as PIM Dense on VLAN interface.
    Now I have access to streams. We will do some testing to see how this will work once propagated throughout the network.
