Original Message:
Sent: May 16, 2025 01:48 AM
Subject: Aruba 555 ラジオが無効になる件
スイッチ側でLLDP有効化で上手くいくことがあるので、有効化されていなければお試しください
Stephane Kazuki Chartrand
HPE Aruba Networking
Original Message:
Sent: May 15, 2025 10:26 PM
ご返信ありがとうございます。
ご教授頂いたコマンドで状況確認してみました。
802.3at対応のPoEスイッチ(Cisco 3560CX)に接続していますが
Power Supply : POE-AF と表示されているのでAP-555からは
802.3afのPoEスイッチとして認識されているということでしょうか?
<Aruba555>
9c:8c:d8:cf:cd:e5# show ap bss-table
Please change default password to private ones before any other operator.
Aruba AP BSS Table
bss ess port ip band/ht-mode/bandwidth ch/EIRP/max-EIRP type cur-cl ap n ame in-t(s) tot-t flags
Channel followed by "*" indicates channel selected due to unsupported configured channel.
"Spectrum" followed by "^" indicates Local Spectrum Override in effect.
Num APs:0
Num Associations:0
Flags: a = Airslice policy; A = Airslice app monitoring; c = MBO Cellular Data Capable BSS; d = Deferred Delete Pending; D = VLAN Discovered; E = Enhanced -open BSS without transition mode; I = Imminent VAP Down; K = 802.11K Enabled; m = Agile Multiband (MBO) BSS; M = WPA3-SAE mixed mode BSS; o = Enhanced-open tra nsition mode open BSS; O = Enhanced-open BSS with transition mode; r = 802.11r E nabled; t = Broadcast TWT Enabled; T = Individual TWT Enabled; W = 802.11W Enabl ed; x = MBSSID Tx BSS; 3 = WPA3 BSS;
9c:8c:d8:cf:cd:e5#
9c:8c:d8:cf:cd:e5# show ap allowed-channels
Allowed Channels for AP Type 555 Country Code JP3
PHY Type Allowed Channels
2.4GHz (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
5GHz (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
2.4GHz (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
5GHz (outdoor) 100 104 108 112 116 120 124 128 132 136 140
2.4GHz 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
5GHz 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136
2.4GHz 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
5GHz 40MHz (outdoor) 100-104 108-112 116-120 124-128 132-136
5GHz 80MHz (indoor) 36-48 52-64 100-112 116-128
5GHz 80MHz (outdoor) 100-112 116-128
5GHz 160MHz (indoor) 36-64 100-128
5GHz 160MHz (outdoor) 100-128
5GHz (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
5GHz (ZWDFS) disable
9c:8c:d8:cf:cd:e5# show ap debug system-status | begin "Power Status"
Power Status
Item Value
LLDP Power : 0.0W
Current Operational State : USB power disabled; 2.4GHz radio: disabled, 5GHz radio: disabled, 5GHz secondary radio: 1x1 1dBm
Eth0 HW POE status : POE AF, LLDP power: 0.0W
Eth1 HW POE status : NONE, LLDP power: 0.0W
POE Mode : Shared
<PoEスイッチ>
C3560CX#show power inline
Available:240.0(w) Used:42.5(w) Remaining:197.5(w)
Interface Admin Oper Power Device Class Max
(Watts)
Gi0/1 auto on 11.7 CBW150AX-Q 0 30.0
Gi0/2 auto on 15.4 Ieee PD 0 30.0
Gi0/3 auto on 15.4 Ieee PD 4 30.0
Gi0/4 auto off 0.0 n/a n/a 30.0
Gi0/5 auto off 0.0 n/a n/a 30.0
Gi0/6 auto off 0.0 n/a n/a 30.0
Gi0/7 auto off 0.0 n/a n/a 30.0
Gi0/8 auto off 0.0 n/a n/a 30.0
Original Message:
Sent: May 15, 2025 09:18 PM
SSIDの設定はお済みでしょうか。お手数ですが、show ap bss-table で電波が出力されているかも一度ご確認ください。
また、以下のコマンドでCountry Codeが正しいか、給電が足りているかもご確認いただけますので、一度ご確認ください。
# show ap allowed-channels Allowed Channels for AP Type 325 Country Code JP3-------------------------------------------------PHY Type Allowed Channels-------- ----------------2.4GHz (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 135GHz (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 1402.4GHz (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 135GHz (outdoor) 100 104 108 112 116 120 124 128 132 136 1402.4GHz 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-135GHz 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-1362.4GHz 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-135GHz 40MHz (outdoor) 100-104 108-112 116-120 124-128 132-1365GHz 80MHz (indoor) 36-48 52-64 100-112 116-1285GHz 80MHz (outdoor) 100-112 116-1285GHz 160MHz (indoor) None5GHz 160MHz (outdoor) None5GHz (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 1405GHz (ZWDFS) disable#show ap debug system-status | begin "Power Status"Power Status------------Item Value---- -----Power Supply : POE-ATLLDP Power : Successfully negotiated at 20.2WCurrent Operational State : No restrictions (Overridden by LLDP)HW POE status : POE-AF
Keita Shimono,
Aruba Japan SE Manager & Airheads Leader
Original Message:
Sent: May 15, 2025 11:29 AM
中古で購入したaruba 555をPoE+環境で使おうとセットアップしています。
ネット設定、SSIDなど正常に設定できましたがクライアントからSSIDが
見つかりません。
色々確認してみると本体の下部にLEDがオレンジ点灯で
WEB管理画面のダッシュボードからアクセスポイントを確認すると
該当のアクセスポイントのラジオ0、1、2のチャネル、出力、使用率、ノイズが
「-」表示になっています。
同じ環境でaruba 325を使っていますがこちらはラジオ0、1の
チャネル、出力、使用率、ノイズは数値が表示されています。
aruba 555のファームウェアを8.10から8.12にバージョンアップしても同様です
このような症状の解決策ご存知にかたいらっしゃらないでしょうか?
よろしくお願いします。
Aruba325
