  • 1.  Aruba 555 radio is disabled
    Posted 27 days ago
    I'm trying to set up a used Aruba 555 for use in a PoE+ environment.
    I was able to set up the network settings and SSID correctly, but the SSID cannot be found by the client.
    After checking various things, I found that the LED on the bottom of the unit was lit orange, and when I checked the access point from the dashboard of the web management screen,
    the channel, output, utilization, and noise of radios 0, 1, and 2 of the access point in question were displayed as "-".
    I'm using an Aruba 325 in the same environment, but the channel, output, utilization, and noise of radios 0 and 1 are displayed as numbers.
    The same thing happened even after upgrading the Aruba 555 firmware from 8.10 to 8.12.
    Does anyone know a solution to this problem?
    Thank you in advance.
  • 2.  RE: Aruba 555 radio is disabled
    Posted 27 days ago
    Did you enable IPM? This helps to bring the AP-555 unrestricted online in PoE+ environments.
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 3.  RE: Aruba 555 radio is disabled
    Posted 26 days ago
    When I ran show ap power-mgmt-statistics,
    the Power Supply was POE-AF.
    After enabling LLDP on the PoE switch (Cisco 3560CX),
    and the Power Supply was POE-AT and RADIO started working normally.
    Thanks for your answer.
  • 4.  RE: Aruba 555 radio is disabled
    Posted 27 days ago
    When Limitations be applied due to power restrictions you can see it with this command:
    (host) #show ap power-mgmt-statistics ap-name 00:4e:35:c4:47:06
    AP Power Mgmt Status, Last update at 2019-09-26 16:43:13
    Attr                Value
    LLDP Granted Power  Eth 0: 23.3 Eth 1: 23.3
    LLDP Request Power  Eth 0: 23.3 Eth 1: 23.3
    Temperature         Highest temperature: 52°C, Lowest temperature: 48°C, Current temperature: 50°C
    Power Supply        POE-AT
    USB Status          USB Knob: Auto, USB Status: Disabled
    PSE Status          N.A.
    ETH Status          Eth 0:Enabled. Eth 1:Disabled.
    G-radio Chain       4*4
    G-radio Enable      Enabled
    G-radio Power       Full Power
    A-radio Chain       4*4
    A-radio Enable      Enabled
    A-radio Power       Full Power
    CPU Throttle        100%
    Power Consumption   7.6W
    IPM Enable          Disabled
    ITM Status          Thermal Standby
    Reference: https://arubanetworking.hpe.com/techdocs/CLI-Bank/Content/aos8/sh-ap-pwrmgmt-stat.htm
  • 5.  RE: Aruba 555 radio is disabled
    Posted 26 days ago
