  • 1.  Aruba 620 PPTP VPN not working
    Posted Jul 07, 2015 11:11 AM
    I bought myself a Aruba 620 controller. Wich works fine. I was trying to setup a PPTP VPN.
    I have forwared the 1723 port to my controller. I am trying to login with the admin account. I cannot get it to work. Do I need to give de admin vpn rights somehow?
    I am trying to start the vpn from ios and windows 8.1. See attached pic for my vpn setup.
  • 2.  RE: Aruba 620 PPTP VPN not working
    Posted Jul 07, 2015 12:51 PM
    Do you have the VPN Portion of your Controller configured?
    Did you also look at the VPN portion of the user guide?  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/VPNs/VPNs.htm%3FTocPath%3DVirtual%2520Private%2520Networks%2520(VPNs)%7C_____0
  • 3.  RE: Aruba 620 PPTP VPN not working
    Posted Jul 07, 2015 01:55 PM
    hi, thanks for your reply:
    Everything is set as default. (see pic)
    Is it Okay if I am using my admin account to test the connection? Do i need to give the admin account certain vpn rights/roles?
