Wired Intelligent Edge
Aruba 620 Wireless Controller Console Cable
  • 1.  Aruba 620 Wireless Controller Console Cable
    Posted Jun 05, 2020 08:38 PM
    Hi;
    I have an Aruba 620 controller with an unknown password..
    The laptop has no serial port or rj45 port only usb. Will a rg45 to usb adapter allow access to change password and check configuration using a crossover cable?
    The desktop has a rj45, usb, and serial port but only have rj45 crossover cables.
    So how can i get in to change password and check the AP's? Dont want to pay $1000's to get tech support either.
    Also what program is used to login? the IP address of the controller is 192.168.0.1.
    Thank you
  • 2.  RE: Aruba 620 Wireless Controller Console Cable
    Posted Jun 07, 2020 08:48 AM
    Hi, have a read here.
