Now it works. I hadto enter the command: "vsf secondary-member 2"
Before there was a master and a member --> now there is a master and a standby and now the split detection work when they are directly connected.
Tomorrow I will try to do the split detection over a L2 VLAN on the Access switches because the 6300m are not in the same building.
I will let you know if it works as expected
