Cloud Managed Networks
Aruba 635 Console cable
This thread has been viewed 22 times
  • 1.  Aruba 635 Console cable
    Posted Jul 11, 2024 12:41 PM
    I was hoping someone could verify one of these console cables were compatible with the 635 APs.
    AP-CBL-SERU  or AP-MOD-SERU
    Thanks in advance,
    Howard
  • 2.  RE: Aruba 635 Console cable
    Posted Jul 11, 2024 02:09 PM
    Edited by schmelzle Jul 11, 2024 02:22 PM
    Either will work with the proprietary "Micro-USB" console port on the indoor APs.
    AP-MOD-SERU is a Micro-USB TTL3.3V to RJ45 RS232 adapter. So, you'd also need a RJ45 RS232 cable in addition to the AP-MOD-SERU.
    AP-CBL-SERU is a Micro-USB TTL3.3V to USB-A (USB 2.0) console cable. I suggest also purchasing a USB-A 2.0 extension cable.
