Wired Intelligent Edge
  • 1.  Aruba 6410 Switch - # FAN Speed went max
    Posted May 17, 2022 12:57 PM
    # show environment fan
    ESSNROWEB18# show environment fan
    Fan tray information
    Name Description Status Serial Number Fans
    1/1 R0X32A Aruba 6400 Fan Tray ready SG0AKMH0FJ 4
    1/2 R0X32A Aruba 6400 Fan Tray ready SG0AKMH187 4
    1/3 R0X32A Aruba 6400 Fan Tray ready SG0AKMH0GD 4
    1/4 R0X32A Aruba 6400 Fan Tray ready SG0AKMH0RJ 4
    Fan information
    Mbr/Fan or Product Serial Number Speed Direction Status RPM
    Mbr/Tray/Fan Name
    1/1/1 N/A N/A max front-to-back ok 13894
    1/1/2 N/A N/A max front-to-back ok 13845
    1/1/3 N/A N/A max front-to-back ok 13943
    1/1/4 N/A N/A max front-to-back ok 13943
    1/2/1 N/A N/A max front-to-back ok 13894
    1/2/2 N/A N/A max front-to-back ok 13845
    1/2/3 N/A N/A max front-to-back ok 13894
    1/2/4 N/A N/A max front-to-back ok 13845
    1/3/1 N/A N/A max front-to-back ok 13797
    1/3/2 N/A N/A max front-to-back ok 13845
    1/3/3 N/A N/A max front-to-back ok 13797
    1/3/4 N/A N/A max front-to-back ok 13748
    1/4/1 N/A N/A max front-to-back ok 13894
    1/4/2 N/A N/A max front-to-back ok 13894
    1/4/3 N/A N/A max front-to-back ok 13797
    1/4/4 N/A N/A max front-to-back ok 13894
    ESSNROWEB18# show environment temperature
    Temperature information
    Current
    Mbr/Slot-Sensor Module Type temperature Status
    I am using Aruba 6410 Switch - FANs went max speed - It's making noise ( sound is  more )
    How to resolve this issue, Please help me
    1/11-Switch-ASIC line-card-module 0.00 C fault
    Elumalai Seetharaman
  • 2.  RE: Aruba 6410 Switch - # FAN Speed went max
    Posted May 17, 2022 06:27 PM
    Hello Elumalai, what is the ArubaOS-CX software version your Aruba 6410 is currently running on? If the Switch ASIC Line Card Module temperature sensor reports 0.00 °C it means that there could be an Hardware issue. Read here, as example.
    Davide Poletto
