  • 1.  >>> Aruba 7210 Model - Aruba OS 8.10.0.9 - Troubleshooting SNMP OIDS Required
    Posted Feb 07, 2024 06:47 AM
    Hi we are running Aruba 7210 Model - ArubaOS 8.10.0.9 x 4 (Aruba 515 AP's)
    In terms of troubleshooting WIFI issues (in particular where devices are disconnecting from the WIFI network), which SNMP OIDS would be recommended for identifying the causes etc. Please give me about 10.
  • 2.  RE: >>> Aruba 7210 Model - Aruba OS 8.10.0.9 - Troubleshooting SNMP OIDS Required
    Posted Feb 07, 2024 09:36 AM
    We would recommend opening a case with TAC, using AirWave for monitoring, and setting debugs around the particular devices that are having problems.
    Carson Hulcher, ACEX#110
  • 3.  RE: >>> Aruba 7210 Model - Aruba OS 8.10.0.9 - Troubleshooting SNMP OIDS Required
    Posted Feb 08, 2024 11:06 AM
    Not sure what your trying to do, but just do an SNMPwalk on the device will give you all OID results. Be careful doing a walk on production environments because it can affect device performance.
    If you need published MIBs you can get them here: https://github.com/librenms/librenms/tree/master/mibs/arubaos
    From your description of what your trying to do you might be better of getting a training class on troubleshooting Aruba Wi-Fi or like previously mentioned open a Support Case.
  • 4.  RE: >>> Aruba 7210 Model - Aruba OS 8.10.0.9 - Troubleshooting SNMP OIDS Required
    Posted Feb 08, 2024 12:03 PM
    Hi in terms of troubleshooting WIFI problems (such as disconnections etc) which is the best Aruba MIB to explore?
