Hi
I'm fairly new for Aruba and have a problem with our new 8320 devices to upgrade the SW from HPE IMC. IMC is connected to our Mgmt NW as is the switch via Mgmt port.
I get cURL error (28) Network is Unreachable. Obviousy since the TFTP copy request runs from the default vrf and not from the Mgmt vrf.
Is there a way to edit the IMC script? If not I'd need some help to configure a static route to the IMC in default vrf to Point the next hop to Mgmt vrf...if Possible.
Cheers
/timo
