AFAIK both Aruba 8320/8400X provide Fan(s) working with the Front-to-Back airflow direction rule.
Given that I'm not able to understand if there are specific Fan(s) Hardware designs restrictions on both platforms with regards to expected airflow...I've this question: Will airflow's direction management (Front-to-Back versus Back-to-Front) be ever supported through Software (supposing it is yet by Hardware) on these platforms as it happens on most HPE FlexFabric switch series?
We try to get an strict and common Hot/Cold airflow separation on each DC Rack we have but our Aruba 8320 pair (ToR), sharing the same Rack with SAN Storages/Switches designed to run with Back-to-Front airflow direction, is causing a weak undesired local airflow loop.
Up to now that is not worrying us too much - top Aruba 8320 internal temperatures are below 36°C despite its inlet air temperature isn't 16°C as it should be due to the airflow local loop (that's the supposed fresh inlet air temperature on the Rack backside) - it's just annoying since neighbour switches are capable of running colder by just respecting the set airflow direction.
As you can image...we can't simply reverse the Aruba 8320 mounting direction inside the Rack since FO cables arrive all at Rack backside (which is the frontside of all Switches).
