Wired Intelligent Edge
  • 1.  Aruba 8360 Switch Maximum VXLAN
    Posted Jul 05, 2021 02:25 PM
    Hi Community,
     What is Limitation of VXLANs in Aruba 8360 Switch
    Dinusha Chandrasinghe - MVP | ACMP | ACSP |ACCA
    Network Engineer
    Plexus Global (Pvt) Ltd
    Colombo Sri Lanka
    +94717327420
  • 2.  RE: Aruba 8360 Switch Maximum VXLAN
    Posted Jul 06, 2021 01:55 AM
    Do you have access to 8360 ? you can look switch capabilites (on CLI)
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Aruba 8360 Switch Maximum VXLAN
    Posted Jul 06, 2021 04:14 AM
    Scale for EVPN is usually very dependent on the network design requirements: is it pure L2, mix L2+L3, centralized L3, distributed L3, only L3 (alternative to MPLS L3VPN). Number of VTEPs, single Fabric, multi-Fabric, number of VRFs, number of BGP RR-clients.
    Hence, I encourage you to reach to your local Aruba SE in order to help reviewing the project and associated design for sizing.
    Vincent Giles
  • 4.  RE: Aruba 8360 Switch Maximum VXLAN
    Posted Jul 08, 2021 12:50 AM
    No, This is Design solution for Customer Requirements
    Network Engineer
    Colombo Sri Lanka
    +94717327420
  • 5.  RE: Aruba 8360 Switch Maximum VXLAN
    Posted Jul 08, 2021 03:32 AM
    Here is the show capacities of the 8360. But please note that this is informational only, and further qualification is required
    for multi-dimensional aspect of the qualification: like number of VTEP+number of VRFs+other things like number of iBGP RR clients..all at the same time.
    So please get in touch with Aruba Consultant Engineer who will help you reviewing the design.
    Aggregation-Leaf    114688 L2 entries, 163840 Host entries, 65536 Route entries (Default)
    Core-Spine          32768 L2 entries, 65536 Host entries, 630784 Route entries
    Leaf-Extended       212992 L2 entries, 16384 Host entries, 65536 Route entries
    Aggregation-Leaf
    (Default)
    Leaf-Extended Core-Spine
    Maximum number of active gateway vmacs configurable 16 16 16
    Maximum number of BFD sessions configurable in a system 256 256 256
    Maximum number of AS numbers in BGP as-path attribute 32 32 32
    Maximum number of BGP as-path entries in a single aspath-list 128 128 128
    Maximum number of aspath-lists 256 256 256
    Maximum number of community entries in a single community-list 128 128 128
    Maximum number of community-lists 256 256 256
    Maximum number of equal cost paths 8 8 8
    Maximum number of BGP neighbors allowed across all VRFs 256 256 256
    Maximum number of BGP peer groups allowed across all VRFs 128 128 128
    Maximum number of routes accepted from a BGP peer 32500 32500 300000
    Maximum number of routes in BGP RIB 65000 65000 600000
    Maximum number of BGP route reflector clients allowed across all VRFs 256 256 256
    Maximum number of Access Control Entries configurable in a system 128000 128000 128000
    Maximum number of Object Group Entries configurable in a system 4000 4000 4000
    Maximum number of Object Groups configurable in a system 4000 4000 4000
    Maximum number of Access Control Lists configurable in a system 8000 8000 8000
    Maximum number of class entries configurable in a system 128000 128000 128000
    Maximum number of classes configurable in a system 4000 4000 4000
    Maximum number of entries in an Access Control List 16000 16000 16000
    Maximum number of entries in a class 16000 16000 16000
    Maximum number of entries in an Object Group 1024 1024 1024
    Maximum number of entries in a policy 256 256 256
    Maximum number of classifier policies configurable in a system 4000 4000 4000
    Maximum number of policy entries configurable in a system 4000 4000 4000
    Maximum number of dynamic VLANs that can be allowed using MVRP 1024 1024 1024
    Maximum number of GBP Role Mappings 256 256 256
    Maximum number of nexthops per IP ECMP group 8 8 8
    Maximum number of IP neighbors (IPv4+IPv6) supported in the system 163840 16384 65536
    Maximum number of GRE IPv4, "IPv6 in IPv4" and "IPv6 in IPv6" tunnels in a system 127 127 127
    Maximum number of IP Directed Broadcast Neighbors supported in the system 4096 4096 4096
    Maximum number of ipsla responder sessions configurable in a system 500 500 500
    Maximum number of ipsla source sessions configurable in a system 500 500 500
    Maximum number of IPv4 neighbors(# of ARP entries) supported in the system 163840 16384 65536
    Maximum number of IPv6 neighbors(# of ND entries) supported in the system 163840 16384 65536
    Maximum number of Keychains supported in the system 64 64 64
    Maximum number of Keys supported in a single Keychain 64 64 64
    Maximum number of Keys supported in the system 4096 4096 4096
    Maximum number of L2 MAC addresses supported in the system 114688 212992 32768
    Maximum number of L3 Groups for IP Tunnels and ECMP Groups 2000 2000 2000
    Maximum number of L3 Destinations for Routes, Nexthops in Tunnels and ECMP groups 4093 4093 4093
    Maximum number of configurable LAG ports 54 54 54
    Maximum number of members supported by a LAG port 16 16 16
    Maximum number of VLANs across ports allowed in loop-protect 10240 10240 10240
    Maximum number of configurable VSX ports 54 54 54
    Maximum number of members supported by a MCLAG port 16 16 16
    Maximum number of IGMP/MLD groups supported 8192 8192 8192
    Maximum number of IGMP/MLD snooping groups supported 8192 8192 8192
    Maximum number of IGMP/MLD static groups supported 8192 8192 8192
    Maximum number of Mirror Sessions configurable in a system 4 4 4
    Maximum number of enabled Mirror Sessions in a system 4 4 4
    Maximum number of MSDP Peers supported 64 64 64
    Maximum number of MSDP SA Cache entries supported 32768 32768 32768
    Maximum number of mstp instances configurable in a system 64 64 64
    Maximum number of NAE agents in a system 50 50 50
    Maximum number of NAE monitors in a system 150 150 150
    Maximum number of NAE scripts in a system 25 25 25
    Maximum number of OSPFv2 areas configurable in the system 128 128 128
    Maximum number of OSPFv2 interfaces configurable in the system 128 128 128
    Maximum number of OSPFv2 interfaces per area in the system 128 128 128
    Maximum number of OSPFv2 processes supported across each VRF 8 8 8
    Maximum number of OSPFv3 areas configurable in the system 128 128 128
    Maximum number of OSPFv3 interfaces configurable in the system 128 128 128
    Maximum number of OSPFv3 interfaces per area in the system 128 128 128
    Maximum number of OSPFv3 processes supported across each VRF 8 8 8
    Maximum number of PBR Action Lists configurable in a system 256 256 256
    Maximum number of PBR Action List entries configurable per PBR Action List 8 8 8
    Maximum number of PIM/PIMv6 mroutes supported 8192 8192 8192
    Maximum number of PIM/PIMv6 nexthops supported 65536 65536 65536
    Maximum number of RBAC rules per user group 1024 1024 1024
    Maximum number of RIP interfaces configurable in the system 32 32 32
    Maximum number of RIP processes supported across each VRF 1 1 1
    Maximum number of routes in RIP supported across all VRFs 10000 10000 10000
    Maximum number of RIPng interfaces configurable in the system 32 32 32
    Maximum number of RIPng processes supported across each VRF 1 1 1
    Maximum number of routes in RIPng supported across all VRFs 10000 10000 10000
    Maximum number of prefix entries in a single prefix-list 128 128 128
    Maximum number of prefix-lists 256 256 256
    Maximum number of route map entries in a single route-map 128 128 128
    Maximum number of route-maps 256 256 256
    Maximum number of RPVST VLANs configurable on the system 254 254 254
    Maximum number of RPVST VPORTs supported in a system 2048 2048 2048
    Maximum number of SMARTLINK GROUPS configurable in a system 24 24 24
    Maximum number of SVIs supported in the system 4094 4094 4094
    Maximum number of unique GRE IPv4, "IPv6 in IPv4" and "IPv6 in IPv6" tunnel local IPs in a system 127 127 127
    Maximum number of unique GRE IPv4, "IPv6 in IPv4" and "IPv6 in IPv6" tunnel TTLs in a system 4 4 4
    Maximum number of active UDLD interface 52 52 52
    Maximum number of routes (IPv4+IPv6) on the system 65536 65536 630784
    Maximum number of IPv4 routes on the system 65536 65536 630784
    Maximum number of IPv6 routes on the system 65536 65536 630784
    Maximum number of VLANs supported in the system 4094 4094 4094
    Maximum number of VLAN Translation rules supported 4000 4000 4000
    Maximum number of unique IPv4 VRRP VRIDs configurable between 1 to 255 8 8 8
    Maximum number of unique IPv6 VRRP VRIDs configurable between 1 to 255 8 8 8
    Maximum number of VRRP IPv4 addresses supported 1024 1024 1024
    Maximum number of VRRP IPv4 addresses supported per virtual router 16 16 16
    Maximum number of VRRP IPv4 virtual routers supported per port 8 8 8
    Maximum number of VRRP IPv6 addresses supported 512 512 512
    Maximum number of VRRP IPv6 addresses supported per virtual router 8 8 8
    Maximum number of VRRP IPv6 virtual routers supported per port 8 8 8
    Maximum number of VRRP virtual routers supported 256 256 256
    Maximum number of VXLAN interfaces in a system 1 1 1
    Maximum number of L2VNIs per VXLAN interface 4093 4093 4093
    Maximum number of L3VNIs per VXLAN interface 255 255 255
    Maximum number of VNIs per VXLAN interface 4093 4093 4093
    Maximum number of VTEPs per VXLAN interface 1024 1024 1024
    Vincent Giles
  • 6.  RE: Aruba 8360 Switch Maximum VXLAN
    Posted Jul 12, 2021 03:52 AM
    Hi Vincent,
    Thank you. We have negotiated exact requirements with the customer.  Actually, they didn't have a VXLAN level requirement.
    Network Engineer
    Colombo Sri Lanka
    +94717327420
