Aruba Central is the cloud based mgmt for Aruba gear.
9004 gateway can run AOS10 firmware which needs Aruba Central or it can run AOS8 firmware.
in your case since you dont have Aruba Central then 9004 will have AOS8 firmware and will be your controller for Aruba APs.
Original Message:
Sent: Jun 26, 2023 03:50 AM
Subject: Aruba 9004
hi ariyap thanks for the comment,
anyway wireless gateway and wireless controller are the same think ? because this is my first time handle aruba gateway series, so i dont familiar with terms that used by aruba gateway series
and what is the aruba central ? if i dont have it what happend then ?
thanks
Original Message:
Sent: Jun 26, 2023 03:39 AM
Subject: Aruba 9004
yes you can use 9004 as a SD-WAN/Wireless gateway.
You can also use AP-565s to tunnel user traffic to the gateway or just bridge the user traffic , this is done through configuration.
Do you have Aruba Central for them?
Original Message:
Sent: Jun 26, 2023 02:36 AM
Subject: Aruba 9004
hi all,
can i use aruba 9004 as the controller of my controller which is AP 565 series ? if not, can i configure one of my AP 565 as virtual controller for others AP ?
all advice are appreciate
