9114 are always managed via Aruba Central. Monitor only group is not available for gateways.
It is possible to do local changes. However, keep in mind that the changes will be overwritten by Central when Disaster Recovery mode is disable.
Local configuration changes are done using the Disaster Recovery mode. (disaster-recovery on). Please check the documentation
Willem Bargeman
Systems Engineer Aruba
ACEX #125
Original Message:
Sent: Mar 05, 2025 03:22 PM
Subject: Aruba 9114 Gateway Enable CLI Configurations
I have a 9114 Gateway that I'm trying to make configuration changes through the CLI, but it is currently managed by the Cloud Platform.
Is there a way for me to enable CLI configuration changes?
I'm not able to get the Gateway back on the Cloud platform to move it to a monitoring group.
Thank you,
FM
Much Appreciated
