Skip main navigation (Press Enter).
Log in
Toggle navigation
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
HPE Aruba Networking Central Status
Live + Virtual Events
Webinar Archive
Upcoming Events
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Community Home
Discussion
123K
Members
3.6K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
This thread has been viewed 27 times
VinmarMagto
Dec 21, 2022 11:53 AM
Does the new Aruba 9240 Gateway/Controller support 1G copper SFP transceiver (J8177D)? I cant find a ...
parnassus
Dec 22, 2022 06:22 AM
Have a look at the Aruba 9200 Series Campus Gateways Ordering Guide , apparently the SKU J8177D is ...
VinmarMagto
Dec 22, 2022 09:46 PM
A colleague just found this slide in a presentation. Apparently it is listed below as one of the tested ...
parnassus
Dec 23, 2022 11:40 AM
That's the reason why I used the word "apparently"... ------------------------------------------- ...
1.
0
Kudos
VinmarMagto
Posted Dec 21, 2022 11:53 AM
Reply Privately
Options Dropdown
Does the new Aruba 9240 Gateway/Controller support 1G copper SFP transceiver (J8177D)? I cant find a documentation anywhere to confirm.
2.
RE: Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
0
Kudos
parnassus
MVP EXPERT
Posted Dec 22, 2022 06:22 AM
Reply Privately
Options Dropdown
Have a look at the
, apparently the SKU J8177D is not a supported option.
Original Message
Original Message:
Sent: Dec 21, 2022 01:18 AM
Subject: Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
3.
0
Kudos
VinmarMagto
Posted Dec 22, 2022 09:46 PM
Reply Privately
Options Dropdown
A colleague just found this slide in a presentation. Apparently it is listed below as one of the tested and validated Transceivers. Can anyone validate?
Original Message
Original Message:
Sent: Dec 22, 2022 06:22 AM
Have a look at the
Original Message:
4.
0
Kudos
parnassus
MVP EXPERT
Posted Dec 23, 2022 11:40 AM
Reply Privately
Options Dropdown
Original Message
Original Message:
Sent: 12/22/2022 9:46:00 PM
Subject: RE: Aruba 9240 Gateway Supports 1G Copper Transceiver (J8177D)?
Original Message:
Have a look at the
Original Message:
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
visio transceiver stencils
fabianfabianfabian
Added May 31, 2019
Discussion Thread
1
Atmosphere 2015 WLAN design & lessons learned Presentation Slides
efisher214
Added Mar 18, 2015
Discussion Thread
3
RE: Atmosphere 2015 WLAN design & lessons learned Presentation Slides
dhanraj_puduchery@yahoo.com
Added Mar 18, 2015
Library Entry
Transceivers command for Mobility Controllers?
vf556
Added Sep 25, 2019
Discussion Thread
2
Redundancy with two 9240 Gateways across Datacenters
mark.bossert
Added Apr 12, 2024
Discussion Thread
4
Copyright 2024. All rights reserved.
Powered by Higher Logic
