  • 1.  Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Sep 01, 2014 09:57 AM
    Good day,
    First time testing out the IAP to RAP conversion on Activate to associate an IAP to a controller.
    It seems obviously simple.
    1. Create a folder you want to place the IAPs you want converted into RAPs
    2. Create a rule for that folder to convert IAPs to RAPs, my rule is below.
    Move the AP to the folder you created (which should inherit the rule you created).
    Connect IAP (in this case IAP-115-RW, firmware 4.0+) to the internet, boot it up and wait.
    Nothing happens. It does not convert to RAP  (even though activate now says it is provisioned and it is a RAP).
    From console, once it boots, I get user/pass which is a giveaway it is not a RAP. I cannot ping my controller IP right away but after 1 or 2 min I CAN ping it.
    Am I missing something here?
  • 2.  RE: Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Sep 01, 2014 09:58 AM
    Did you do a hard reset?
  • 3.  RE: Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Sep 01, 2014 11:51 PM
    In the Activate logs it should tell you if it was able to reach the activate cloud server?
    Also is the mac address in the rap whitelist on the controller ?
  • 4.  RE: Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Sep 02, 2014 12:31 PM
    Hard reset was done
    RAP was white listed on the controller.
    What activate logs? :) where do you see those?
  • 5.  RE: Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Sep 02, 2014 12:32 PM
    show activate status
  • 6.  RE: Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Sep 02, 2014 12:35 PM
    I'll give my AP another shot
    Pasquale Monardo
    Conseiller Principal Solution R?seaux, Op?ration | Senior Network Solutions Consultant, Operation
    [cid:image001.png@01CFC6AA.4AC88930]
    T 514 385-4448 #204 DATAVALET.COM
    5275, chemin Queen-Mary, Montr?al (Qu?bec) H3W 1Y3 Canada
    CE COURRIEL AINSI QUE CES DOCUMENTS JOINTS peuvent contenir des renseignements confidentiels et privil?gi?s. Si vous n'?tes pas le destinataire d?sign?, veuillez nous en informer imm?diatement et effacer toute copie. Merci. THIS EMAIL AND THE DOCUMENTS ATTACHED may contain privileged or confidential information. If the reader of this message is not the intended recipient, please notify the sender immediately and delete the original message. Thank you.
  • 7.  RE: Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Sep 03, 2014 09:00 AM
    so got it hooked up and what I see now from 'show activate status' is success with an Airwave key. Odd because I have not told it to go to an Airwave server but to convert to a RAP and go to a particular controller IP.
    On Activate I see the following:
    I see success but there was no success. Never came on up on the controller
    I also see it trying to go back to a previous VC on the 184 IP. Why? I don't know.
    It is empty, no config, brand new.
    My rule on activate has not changed.
    I then decided to downgrade the IAP to 3.4.0.3 because my controller is on the 6.1 train. The IAP I am ussing now is a 105.
    I now see in the logs the following:
    Success = no success in my case. The only AP in my folder and rule is my 105 why another error shows up with 4.1 IAP-SUB I have no clue...
  • 8.  RE: Aruba Activate not converting IAP to RAP? Am I missing something.
    Posted Dec 14, 2016 04:56 PM
    I realize this is an old thread, but I recently had an issue with this, so I wanted to pass along some knowledge
    The following CLI commands should help narrow down the cause.
    show log convert
    show upgrade info
    I would also stress that you double check that you have whitelisted and you have the available licensing. ( I'm sure you've checked both of these many times)
