Become a Member
Aruba Airwave Top Header Stats not Client
Help me understand the lack of customer monitoring
APs\Monitor - screenshot - Aruba - Status UP - all
Are you seeing any actula clients associated to those AP/IAPs in controller/VC?
Are you montioring controller or IAPs? Can you check if AMP Setup>General>Aruba Instant Option>Configuration Only: is set to YES, change to NO.
Pavan
Yes,
Set to YES
Change to NO and check the status.
