Wired Intelligent Edge
  • 1.  Aruba AOS-CX in EVE-NG LACP Blocked Issue 10.09
    Posted Aug 23, 2024 03:26 AM
    Hey! I have a topology as follows; There is HA between FortiGates and there is Aggregate that contains VLANs on port5-port6 and no problem with the config for sure. And Kat-1-L2, Kat-2-L2, Kat-3-L2, Kat-1-2-L2 switches has all vlans and trunks configured well. So no problem with them. SW-L3-A-1 has vsx between SW-L3-A-2. If I don't start SW-L3-A-2 there is no problem, every switch can access each other but if I start it then all lacp ports blocking and nothing works. I have no idea why. L3-A-1 and L3-A-2 configs in the below. (LAG256 was working very well when only Fortigates and SW-L3-A-1, SW-L3-A-2 works. When I start L2 Switches then it stopped)
    This is what "sh lacp int" says when I start A-2;
    SW-L3-A-1 configuration;
    hostname SW-L3-A-1
    lacp system-priority 100
    user admin group administrators password ciphertext AQBapdOyMVI/aHJ49fx9rz4K3RAwC2qm1ov9omOnwJZFKnFBYgAAALCHxtu2O24d03aJr49vrD7I6UjNBlX39Vh03MZd0KMBymU9eJIFfKwm2MOgu2Aqhar1tvzQi6S2WMbTu2oIUH8PS+UwVRtXFGgdaIBeJ2mJpfHGTHzHImXGbqoi022pMQtf
    led locator on
    vrf keepalive
    ntp server pool.ntp.org minpoll 4 maxpoll 4 iburst
    ntp enable
    ssh server vrf mgmt
    vlan 1
    vlan 1100
        name BoardOfDirect
    vlan 1101
        name HR
    vlan 1105
        name AR-GE
    vlan 1106
        name IT
    vlan 1110
        name Sales
    vlan 1120
        name Marketing
    vlan 1132
        name NetworkDevice
    vlan 1145
        name ServerDevice
    interface mgmt
        no shutdown
        ip dhcp
    interface lag 1
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed all
        lacp mode active
    interface lag 256
        no shutdown
        description ISL
        no routing
        vlan trunk native 1 tag
        lacp mode active
    interface 1/1/1
        no shutdown
        ip address 10.1.91.7/24
    interface 1/1/2
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/3
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/4
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/5
        no shutdown
        lag 1
    interface 1/1/6
        no shutdown
        lag 1
    interface 1/1/7
        no shutdown
        lag 256
    interface 1/1/8
        no shutdown
        lag 256
    interface 1/1/9
        no shutdown
        vrf attach keepalive
        description VSX keepalive
        ip address 192.168.99.1/30
    interface vlan 1132
        ip address 10.8.3.2/25
    vsx
        inter-switch-link lag 256
        role primary
        keepalive peer 192.168.99.2 source 192.168.99.1 vrf keepalive
        vsx-sync vsx-global
    ip route 0.0.0.0/0 10.8.3.1
    SW-L3-A-2 configuration;
    hostname SW-L3-A-2
    user admin group administrators password ciphertext AQBapWhfUon6JJWNQk/xDaGakfV8e/n6Cj09DuDQ9OjzXDmNYgAAAMLEsLdP5myg5irLsam+Eg8QkzRW3vVdow85nPADFXe1PXXany7ko0wJc6kp10OLzfmXzqnyWdZYR2yJE14y6PxhMBkDXFJUdoBHhXqCfezf/6gcfmF4jSMIAZi8+qhAAFMC
    led locator on
    vrf keepalive
    ntp enable
    ssh server vrf mgmt
    vlan 1
    vlan 1100
        name BoardOfDirect
    vlan 1101
        name HR
    vlan 1105
        name AR-GE
    vlan 1106
        name IT
    vlan 1110
        name Sales
    vlan 1120
        name Marketing
    vlan 1132
        name NetworkDevice
    vlan 1145
        name ServerDevice
    interface mgmt
        no shutdown
        ip dhcp
    interface lag 1
        no shutdown
        no routing
        vlan trunk native 1
        lacp mode active
    interface lag 256
        no shutdown
        description ISL
        no routing
        vlan trunk native 1
        lacp mode active
    interface 1/1/1
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/2
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/3
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/4
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/5
        no shutdown
        lag 1
    interface 1/1/6
        no shutdown
        lag 1
    interface 1/1/7
        no shutdown
        lag 256
    interface 1/1/8
        no shutdown
        lag 256
    interface 1/1/9
        no shutdown
        ip address 192.168.99.2/30
    interface vlan 1132
        ip address 10.8.3.3/25
    vsx
        role secondary
        keepalive peer 192.168.1.1 source 192.168.1.2 vrf keepalive
        vsx-sync vsx-global
  • 2.  RE: Aruba AOS-CX in EVE-NG LACP Blocked Issue 10.09
    Posted Aug 24, 2024 08:27 AM
    Do you have MC LAG at the Fortigates? If you don't have MCLAG at the FortiGates yoy need it an the CX side.
    interface lag 1 multi-chassis
        no shutdown
        no routing
        vlan trunk native 1
        lacp mode active
    interface lag 2 multi-chassis
        no shutdown
        no routing
        vlan trunk native 1
        lacp mode active
    interface 1/1/5
        no shutdown
        lag 1
    interface 1/1/6
        no shutdown
        lag 2
    Without spanning-tree yout L2 topology creates loop.
    And the simulators don't have a functional STP, it forwards packets out on blocked interfaces.
    On Kat-2 and Kat-3 you may create a LAG and a MCLAG on your VSX to avoid the loop.
    On Kat-1-2 you must remove one of the links to upstream switch becase you cant avoid to create a loop there.
    Arne Opdal
  • 3.  RE: Aruba AOS-CX in EVE-NG LACP Blocked Issue 10.09
    Posted Aug 24, 2024 04:37 PM
    Thank you so much. I made a change in the topology because there was a mistake. The change is SW-L3-A-2 1/1/4 port to Kat-1-L2. It was 1/1/4 to Kat-1-2-L2. When I create multi-chassis lags on L3s and normal lags on L2s everything worked well. Now I want to know why, could you please explain it to me. The first thing is we create mclags on L3s and the second is normal lags on L2s. Why we needed to create MCLAGs on L3s and why we dont needed to create MCLAGs on L2s?
    This is what I do and works like a charm;
    SW-L3-A-1 and SW-L3-A-2 configs;
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    interface lag 3 multi-chassis
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    interface lag 4 multi-chassis
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    interface lag 5 multi-chassis
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    interface lag 256
    no shutdown
    description ISL
    no routing
    lacp mode active
    interface 1/1/2
    no shutdown
    lag 3
    interface 1/1/3
    no shutdown
    lag 4
    interface 1/1/4
    no shutdown
    lag 5
    interface 1/1/5
    no shutdown
    lag 1
    interface 1/1/6
    no shutdown
    lag 2
    and Kat-1-L2, Kat-2-L2, Kat-3-L2 configs;
    interface lag 1
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    interface 1/1/3
    no shutdown
    lag 1
    interface 1/1/4
    no shutdown
    lag 1
  • 4.  RE: Aruba AOS-CX in EVE-NG LACP Blocked Issue 10.09
    Posted Aug 25, 2024 07:04 AM
    A LAG is when you are using one or more interfaces on the same device, like your ISL on the VSX members or on the "single device" switches in your lab.
    When using interfaces on two different devices (VSX) you need to configure your LAG in a way that the devices know its spanning both devices. multi-chassis in configuration an VSX LAG in documentation https://www.arubanetworks.com/techdocs/AOS-CX/10.09/HTML/vsx/Content/Chp_Start/vsx-lag-10.11.htm
    If you are running VSF stack with physical devices, its one controlplane so you will use just LAG (not supported on the simulator).
    And enable MSTP to learn, you should use it in your real network even if you design for no loops. The protocol behaves correct, but is non functional when you tries to send packets in the dataplan in the simulator if you have interfaces in blocking state.
    You should also upgrade your simulator to a new release ;-)
    Arne Opdal
  • 5.  RE: Aruba AOS-CX in EVE-NG LACP Blocked Issue 10.09
    Posted Aug 27, 2024 12:43 PM
    • Verify that the LACP system priorities are correctly configured. You have set lacp system-priority 100 on SW-L3-A-1, but this should be consistent across both switches.
    • Check the LACP mode (active) and ensure that it matches on all LAGs (especially LAG 256)
  • 6.  RE: Aruba AOS-CX in EVE-NG LACP Blocked Issue 10.09
