Wired Intelligent Edge
  • 1.  ARUBA AOS CX LDAP CONNECTION PROBLEM WITH TRUNK
    Posted Sep 30, 2024 04:40 AM
    Edited by barisben Sep 30, 2024 06:26 AM
    Hey, I have a problem that something weird. I have Fortigate, Switch and a AD Server. When I want to add LDAP Server to Fortigate, I can't. The problem is If I put a Aruba Switch between Firewall and AD Server, It doesn't work. But Firewall and AD Server can communicate, can ping each other. So there is no problem with it. At this point, If I put a Cisco Switch between them with the Firewall and AD Server same config, there is no problem. I don't understand why Aruba Switch causes this. This is the topology;
    This is Cisco Switch's config;
    boot-start-marker
    boot-end-marker
    no aaa new-model
    ip cef
    no ipv6 cef
    spanning-tree mode pvst
    spanning-tree extend system-id
    interface GigabitEthernet0/0
    switchport trunk allowed vlan 110
    switchport trunk encapsulation dot1q
    switchport mode trunk
    negotiation auto
    interface GigabitEthernet0/1
    switchport access vlan 110
    switchport mode access
    negotiation auto
    interface GigabitEthernet0/2
    negotiation auto
    interface GigabitEthernet0/3
    negotiation auto
    interface GigabitEthernet1/0
    negotiation auto
    interface GigabitEthernet1/1
    negotiation auto
    interface GigabitEthernet1/2
    negotiation auto
    interface GigabitEthernet1/3
    negotiation auto
    ip forward-protocol nd
    ip http server
    ip http secure-server
    ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
    ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
    This is Aruba Switch config;
    led locator on
    ntp server pool.ntp.org minpoll 4 maxpoll 4 iburst
    ntp enable
    ssh server vrf mgmt
    vlan 1
    vlan 110
    name ADSERVER
    interface mgmt
    no shutdown
    ip dhcp
    interface 1/1/1
    no shutdown
    no routing
    vlan trunk native 1
    vlan trunk allowed 110
    interface 1/1/2
    no shutdown
    no routing
    vlan access 110
    https-server vrf mgmt
  • 2.  RE: ARUBA AOS CX LDAP CONNECTION PROBLEM WITH TRUNK
    Posted Sep 30, 2024 05:17 AM
    Hi
    thanks for reaching out to the community.
    To solve your issue, we need a couple of more details / answers to questions:
    • What VLAN is used for the connection between the FortiGate and your AD Server? Is it solely VLAN110 or is there any type of routing which happens on the Cisco switch that perhaps is missing on your Aruba device?
    • If FortiGate has an interface in VLAN110, can you ping it's IP address from the AD controller (FortiGate needs to have "ping" allowed on the respective interface)?
    • Do you see the mac-addresses of your FortiGate and the AD controller on the Aruba switch (--> show mac-address-table)? You may filter the output using "interface" or "vlan" suffixes at the end of the command.
    • Have you checked that the interfaces were in "up" state when testing?
    • Would it be possible to share the full running config of your Cisco and Aruba device
    Thomas
  • 3.  RE: ARUBA AOS CX LDAP CONNECTION PROBLEM WITH TRUNK
    Posted Sep 30, 2024 06:11 AM
    Hi, I edited the main post for full-configurations. I use 110 for ADServer VLAN. I can ping from AD to Fortigate if I put Cisco Switch or Aruba Switch. I can show the mac addresses. Interfaces up for sure.
  • 4.  RE: ARUBA AOS CX LDAP CONNECTION PROBLEM WITH TRUNK
    Posted Sep 30, 2024 06:17 AM
    Hi
    thanks.
    I notice one difference:
    On Cisco. you have your first port (Gi0/0) configured with VLAN110 as tagged (the switch adds a dot1q tag to the ethernet frames) whereas on Aruba you configured it as native (e.g. no tag will be added). This will result in L2 problems between the firewall and the switch as the firewall will most probably have a VLAN configured on port2.
    You may fix it by reverting the native vlan on Aruba's Interface 1/1/1 to 1, vlan trunk native 1.
    If it still doesn't work, please share port2 and vlan110 config of your FortiGate (show system interface).
    Regards.
    Thomas
  • 5.  RE: ARUBA AOS CX LDAP CONNECTION PROBLEM WITH TRUNK
    Posted Sep 30, 2024 06:35 AM
    Edited by barisben Sep 30, 2024 06:35 AM
    Sorry for the missing. It was already native vlan 1 on Aruba, it doesn't work like this. How can I add dot1q tag as Cisco on Aruba?
    edit "port2"
            set vdom "root"
            set type physical
            set snmp-index 2
    edit "AD"
            set vdom "root"
            set ip 10.10.10.1 255.255.255.0
            set allowaccess ping
            set device-identification enable
            set role lan
            set snmp-index 9
            set interface "port2"
            set vlanid 110
  • 6.  RE: ARUBA AOS CX LDAP CONNECTION PROBLEM WITH TRUNK
    Posted Sep 30, 2024 07:15 AM
    Edited by thomasbnc Sep 30, 2024 07:16 AM
    Hmm, so working with a moving target is a bit difficult here ... We need to have a stable state and work from there. If you ever change the configuration, troubleshooting will fail.
    So, please make sure you have the following config on Aruba:
    int 1/1/1
    no routing
    vlan trunk native 1
    no shutdown
    spanning-tree port-type admin-edge
    int 1/1/2
    no routing
    vlan access 110
    no shutdown
    Then, connect the devices, wait a couple of seconds, run a ping from the AD server to the firewall and run the following commands on Aruba:
    • show int brief
    • show vlan
    • show spanning-tree
    • show mac-address-table vlan 110
    Please share the output of the commands here. Once checked, we made sure Layer2 is okay, then we continue with Layer3 troubleshooting. For reference, please query the mac-addresses of the Fortigate and the AD controller on the respective systems so we can identify they are visible on the switch.
    Regarding your question about the dot1q tag: Aruba adds the tag everytime you configure the port as trunk ("vlan trunk .....") as long as it's not the trunks native VLAN. So, make sure native VLAN is set to 1, the command then disappears from the output of "show run int x/x/x").
    Thomas
  • 7.  RE: ARUBA AOS CX LDAP CONNECTION PROBLEM WITH TRUNK
    Posted Sep 30, 2024 07:28 AM
    Edited by barisben Sep 30, 2024 07:29 AM
    interface 1/1/1
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed all
    interface 1/1/2
        no shutdown
        no routing
        vlan access 110
    switch# sh int brief
    Port      Native  Mode   Type           Enabled Status  Reason                 Speed   Description
              VLAN        (Mb/s)
    1/1/1     1       trunk  --             yes     up                             1000    --
    1/1/2     110     access --             yes     up                             1000    --
    1/1/3     --      routed --             no      down    Administratively down  --      --
    1/1/4     --      routed --             no      down    Administratively down  --      --
    1/1/5     --      routed --             no      down    Administratively down  --      --
    1/1/6     --      routed --             no      down    Administratively down  --      --
    1/1/7     --      routed --             no      down    Administratively down  --      --
    1/1/8     --      routed --             no      down    Administratively down  --      --
    1/1/9     --      routed --             no      down    Administratively down  --      --
    1/1/10    --      routed --             no      down    Administratively down  --      --
    1/1/11    --      routed --             no      down    No XCVR installed      --      --
    1/1/12    --      routed --             no      down    No XCVR installed      --      --
    1/1/13    --      routed --             no      down    No XCVR installed      --      --
    1/1/14    --      routed --             no      down    No XCVR installed      --      --
    switch# sh vlan
    VLAN  Name                              Status  Reason                  Type        Interfaces
    1     DEFAULT_VLAN_1                    up      ok                      default     1/1/1
    110   ADSERVER                          up      ok                      static      1/1/1-1/1/2
    switch# sh spanning-tree
    Spanning tree status      : Enabled Protocol: MSTP
    MST0
      Root ID    Priority   : 32768
                 MAC-Address: 08:00:09:b9:10:5b
                 This bridge is the root
                 Hello time(in seconds):2  Max Age(in seconds):20
                 Forward Delay(in seconds):15
      Bridge ID  Priority  : 32768
    Port         Role           State      Cost           Priority   Type             BPDU-Tx    BPDU-Rx    TCN-Tx     TCN-Rx
    1/1/1        Designated     Forwarding 20000          128        P2P Edge         6          0          0          0
    1/1/2        Designated     Forwarding 20000          128        P2P Edge         6          0          0          0
    Number of topology changes    : 0
    Last topology change occurred : 0 seconds ago
    switch# show mac-address-table vlan 110
    MAC age-time            : 300 seconds
    Number of MAC addresses : 2
    MAC Address          VLAN     Type                      Port
    50:00:00:3a:00:01    110      dynamic                   1/1/1
    50:00:00:3b:00:00    110      dynamic                   1/1/2
