Hi all ,
We have 40+ indoor AP-225 showing amber light .
We connected using Extreme Switch PoE+ as well HP PoE+ Sw , but when AP-325 is used with same switch it works with full power.
We checked AP-225 using Power Injector it works normal ,all are green light
Kindly assist , what may be the issue for AP-225 amber light ?
