  • 1.  Aruba Ap 225 restarting
    Posted Mar 05, 2016 12:46 PM
    Dear All
    i have 7200  series Aruba controller and have 225 model accesspoint few of them are restarting again and again some time after 1 week some time after few hours .
    some one please guide me how to fix the issue
  • 2.  RE: Aruba Ap 225 restarting
    Posted Mar 05, 2016 02:14 PM
    You should open a TAC case to troubleshoot anything that happens intermittently.
    If access points are rebooting, you should be able to see why by typing "show ap debug system-status ap-name <name of ap> | begin rebooted"
    (Aruba7005-US) #show ap debug system-status ap-name Office-225 | begin rebooted
    AP rebooted Fri Mar 4 20:01:15 CST 2016; SAPD: Reboot after successful image upgrade
  • 3.  RE: Aruba Ap 225 restarting
    Posted Mar 07, 2016 12:21 PM
    Can you please run the show AP database from CLI and see if there's any flags ?
    Or from GUI go to AP Installation and see if there's any flags ?
    Sent from Outlook for iPhone
  • 4.  RE: Aruba Ap 225 restarting
    Posted Mar 07, 2016 12:47 PM
    Are the same ones rebooting over and over or just random ones? Same closet/switch?
    Once the controller is ruled out I'd also check the switch and make sure the power budget isn't over subscribed or there isn't a problem with the POE.
