Aruba AP-504 and 7200 controllers
  • 1.  Aruba AP-504 and 7200 controllers
    Posted May 19, 2022 11:23 AM
    Can I deploy ap 504 with 7200 controller as stand alone.
    Karim
    Karim Fatimi
  • 2.  RE: Aruba AP-504 and 7200 controllers
    Posted May 20, 2022 10:11 AM
    The 7200 controller series does support the AP-504. Check the AP datasheet for the minimum firmware version required on your controller.
    If your question is if the AP-504 can be deployed standalone, without a controller... yes that is possible as well as it is a 'Unified AP' which can run in Instant mode without a controller.
  • 3.  RE: Aruba AP-504 and 7200 controllers
    Posted May 23, 2022 11:08 AM
    Thanks Herman,
    My configuration will be 2 x 7200 controllers in 2 different datacenter, one in the east coast and the other in the west coast. Remote APs will be getting their config via VPN tunnel.  Could you please point me to any upgrade 7200 documentation and configuration examples.
    Karim
    Karim Fatimi
  • 4.  RE: Aruba AP-504 and 7200 controllers
    Posted Jun 07, 2022 09:06 AM
    I would really recommend taking training or hiring someone who has been trained. Upgrading and changing configuration is a big risk if you don't know what you are doing.
    If you are trained or feel comfortable doing this yourself, using the Validated Solution Guides may get you started.
