  • 1.  ARUBA AP 515 LED STATUS
    Posted 25 days ago
    One of my AP 515 is showing this LED status
    -Solid Red
    -Green Flashing
    AP powered up using POE Injector, and when i try directly connect it to Poe switch with Poe port that has 30watt also showing the same LED status.
    Any idea whats happening ?
  • 2.  RE: ARUBA AP 515 LED STATUS
    Posted 25 days ago
    Edited by chulcher 25 days ago
    If you are using a PoE injector, make sure to disable PoE on the switch port.
    If you are saying that you are seeing the same LED situation while connected with PoE injector or when connected to a PoE switch, open a case with TAC.
    Carson Hulcher, ACEX#110
  • 3.  RE: ARUBA AP 515 LED STATUS
    Posted 25 days ago
    I did disable the PoE on the switch when using a PoE injector.
  • 4.  RE: ARUBA AP 515 LED STATUS
    Posted 25 days ago
    That is definitely not an expected state, please open a case with TAC to investigate.  If only the one AP is exhibiting the behavior, may be bad or dead hardware.
