  • 1.  Aruba AP315, problem to login to conductor
    Posted 21 days ago
    I have three Aruba AP-315 access points running in the same subnet. One of them acts as the conductor, and I manage the entire setup from there. Here's the setup:
    • AP1 – 10.11.1.42 (conductor)
    • AP2 – 10.11.1.43
    • AP3 – 10.11.1.44
    The issue is that when I'm connected to the WiFi network provided by these APs, I can only access the web interface of AP2 and AP3. I cannot log in to AP1 (the conductor) via WiFi - the management page doesn't load. It only works when I connect my computer using a wired connection.
    It's definitely not a firewall issue - all APs are in the same subnet and VLAN. Two are accessible, one isn't. Could this be some sort of built-in security feature on the conductor that blocks management access over WiFi? If so, how can I disable or reconfigure it?
  • 2.  RE: Aruba AP315, problem to login to conductor
    Posted 21 days ago
    You are getting a User-Role when you access to WiFi. Check the Access List of that User role, if it permits access to 10.11.1.42
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 3.  RE: Aruba AP315, problem to login to conductor
    Posted 20 days ago
    also what firmware version are you running?
  • 4.  RE: Aruba AP315, problem to login to conductor
    Posted 6 days ago
    8.12.0.4 SSR
  • 5.  RE: Aruba AP315, problem to login to conductor
    Posted 6 days ago
    In roles for my wifi network I have everything allowed for each location, i.e. full access, rules for users I don't have, it's my private home network, I don't have user recognition or users themselves in it
  • 6.  RE: Aruba AP315, problem to login to conductor
    Posted 5 days ago
    I have experienced this more than once. Never got to the bottom of it. It just worked itself out. Perhaps the configuration hadn't propagated yet? Or, maybe I performed a factory reset ? I can't remember. But I do know I didn't have to change any settings.
  • 7.  RE: Aruba AP315, problem to login to conductor
    Posted 5 days ago
    I even wrote here about it:
    https://community.arubanetworks.com/discussion/iap-325-gui-unreachable-via-wi-fi-side-but-wi-fi-internet-access-works
  • 8.  RE: Aruba AP315, problem to login to conductor
    Posted 4 days ago
    Hi
    I created a rule from this thread: "Allow app https to AP IP all", in order to access the GUI while connected to the Wi-Fi network. Access to the controller works correctly, as does internet access. Unfortunately, the controller is also accessible from other Wi-Fi networks, not just the one I intended. Another issue is that traffic to the controller no longer passes through the firewall (I have a Palo Alto at the network edge); instead, it seems to be handled locally by the access point, which means I have no control over this traffic.
  • 9.  RE: Aruba AP315, problem to login to conductor
    Posted 4 days ago
    Please check this post I made earlier today. Disable local-routing in order to force all traffic through your firewall; it may also solve the problem that the management interface is accessible from other networks. Please let us know the results after you tried.
  • 10.  RE: Aruba AP315, problem to login to conductor
    Posted 2 days ago
    Hi
    yes, that was it, deny local routing took care of it, thank you very much for your help
