The AP-325s are supported through AOS8.10 (https://www.arubanetworks.com/support-services/end-of-life/#product=access-points&version=0), so no issues upgrading to the latest version of 8.10.
Typically, AP support will not be dropped/removed in the middle of a minor software cycle, so upgrading from 8.10.0.6 to 8.10.0.8 would not be a problem. When in doubt, the release notes and/or the end-of-life table linked above should be helpful.
Original Message:
Sent: Sep 22, 2023 09:02 AM
Subject: Aruba APs - IAP Upgrade after Vulnerability
Hey there,
I've got a couple of 315 - 325 - 515 IAP Cluster with Version 8.10.6 which is vulnerable to a security flaw.
What are my Options here, I'd like to Upgrade to 8.10.08 but I don't think the 325 are supporting that release.
Do I have to buy new 500 series APs or what are my Options here
