Location Services
Aruba Beacon Planning Tool
  • 1.  Aruba Beacon Planning Tool
    Posted Nov 17, 2017 08:43 AM
    Hi Community, do you know if there is any tool in order to plan beacons that can work as RF-Planner in order to have an Idea on how many beacons the implementation needs to have ?
    #Meridian
    #LocationServices
    #ALE
    #ArubaTags
  • 2.  RE: Aruba Beacon Planning Tool
    Posted Nov 23, 2017 07:19 PM
    The following Validated Reference Design will help. Placing every 10 - 15 meters a beacon depending on the area you want to cover will result in accurate indoor location.
    Aruba Beacons Validated Reference Design
