Hi. I added an IAP-215 to My central account. I have 75 other access point mostly IAP-305s.
The AP is Foundation licensed. It is in a group with two SSIDs configured.
But both radio lights are off.
Firmware is 8.6.0.14
log and config is below.
THANKS
b4:5d:50:c2:61:74# sh log system
Dec 14 21:33:12 nanny[4569]: <303079> <ERRS> |AP b4:5d:50:c2:61:
74@192.168.100.136 nanny| Restarted process /aruba/bin/aruba_ntpdate, new pid 5197
Dec 14 21:33:16 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Swarm State Change from Image-ok to DRT-ok.
Dec 14 21:33:26 cli[4656]: <341194> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Loading configuration, func swarm_timer_handler, line 16016.
Dec 14 21:33:26 cli[4656]: <341101> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Execute command-configure terminal.
Dec 14 21:33:42 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| DRT: cli sends sapd regulatory table version US-1.0_81806
74@192.168.100.136 cli| cli send wcd cninfo
74@192.168.100.136 cli| DRT: cli sends wcd regulatory table version US-1.0_81806
74@192.168.100.136 cli| CLI to PAPI port 8571 communication code 1
74@192.168.100.136 cli| CLI to PAPI port 8393 communication code 1
Dec 14 21:33:46 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| wl_vlan: guest, wl_allowed_vlans: 0
74@192.168.100.136 cli| CLI to PAPI port 8359 communication code 1
74@192.168.100.136 cli| no clarity_dnsdhcp process found
74@192.168.100.136 cli| clarity_dnsdhcp launch success
74@192.168.100.136 cli| Do CLI wlan factory
Dec 14 21:33:47 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| default_wired_port_profileignore apply normal port profile to usb port
74@192.168.100.136 cli| Swarm State Change from Image-ok to Complete
74@192.168.100.136 cli| DRT: swarm have no country code, skip to send wcd updated regulatory table
Dec 14 21:33:48 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| is_factory_reset_on_running : Swarm quit factory default status by : ssid_config
Dec 14 21:33:48 cli[4656]: <341326> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| autojoin: get central config flag from flash, flag is TRUE.
Dec 14 21:33:59 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Aruba Central Mgmt
Dec 14 21:34:39 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| athena_redirect launch websocket connecting...
Dec 14 21:34:43 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| wsc_command_execute: 10667: topic='config.audit', payload len=65
74@192.168.100.136 cli| wsc_config_audit: 9793: size=4069
Dec 14 21:34:50 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| wsc_command_execute: 10667: topic='config.delta', payload len=259
Dec 14 21:34:50 cli[4656]: <341251> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| VC record new delta configuration entry. cfg_id 1 current 1 top 0 len 15 port 15200 flags 1 seq 0
74@192.168.100.136 cli| wsc_delta_config
Dec 14 21:34:50 cli[4656]: <341101> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Execute command-arm.
74@192.168.100.136 cli| Execute command-band-steering-mode prefer-5ghz.
74@192.168.100.136 cli| Execute command-client-match calc-interval 3.
74@192.168.100.136 cli| Execute command-client-match nb-matching 60.
74@192.168.100.136 cli| Execute command-client-match calc-threshold 5.
74@192.168.100.136 cli| Execute command-client-match max-request 5.
74@192.168.100.136 cli| Execute command-client-match max-adoption 5.
74@192.168.100.136 cli| Execute command-exit.
74@192.168.100.136 cli| Execute command-end.
Dec 14 21:34:50 cli[4656]: <341072> <ERRS> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| AP could not find post auth role __wired__eth1.
Dec 14 21:34:51 cli[4656]: <341254> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| VC add delta configuration id 2 to msg CLI_EXECUTE_CONFIG_COMMAND.
Dec 14 21:34:51 cli[4656]: <341251> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| VC record new delta configuration entry. cfg_id 2 current 2 top 0 len 200 port 15200 flags 1 seq 0
Dec 14 21:34:51 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| config got from central, set flag to flash.
74@192.168.100.136 cli| Set Auto backup and restore flag on flash
Dec 14 21:34:52 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Clear awc_available flag
Dec 14 21:35:13 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Sending out drt-check request to Activate
Dec 14 21:35:14 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Activate response for 'drt-check': new_drt='1.0_82293' payload='1.0_82293
http://d2vxf1j0rhr3p0.cloudfront.net/drtfiles/reg-data-1.0_82293.dat^M '
Dec 14 21:37:59 syslog: <341004> <WARN> |AP b4:5d:50:c2:61:
Dec 14 21:38:00 cli[7441]: <341004> <WARN> |AP b4:5d:50:c2:61:
Dec 14 21:39:34 cli[7441]: <341101> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Execute command-ping 8.8.8.8.
Dec 14 21:39:52 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Management server connected success, sync primary to backup
74@192.168.100.136 cli| Sending config sync success event to central
Dec 14 21:39:56 cli[4656]: <341251> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| VC record new delta configuration entry. cfg_id 3 current 3 top 0 len 20 port 15200 flags 1 seq 0
Dec 14 21:52:17 cli[4656]: <341004> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| wsc_command_execute: 10667: topic='cmd.action', payload len=167
74@192.168.100.136 cli| apply_swarm_action_cmd: 4134: apply a reverse ssh connection.
Dec 14 21:52:17 cli[4656]: <341101> <WARN> |AP b4:5d:50:c2:61:
74@192.168.100.136 cli| Execute command-ssh rcs-ng-central-prod2.central.arubanetworks.com user iap-1639515040 ssh-port 443 reverse-ssh-port 33139 reverse-https-port 9999 password ************.
Dec 14 21:52:18 syslog: <341004> <WARN> |AP b4:5d:50:c2:61:
Dec 14 21:52:19 cli[11607]: <341004> <WARN> |AP b4:5d:50:c2:61:
b4:5d:50:c2:61:74#
version 8.6.0.0-8.6.0
virtual-controller-country US
virtual-controller-key 5881f29601acc998860aa67d33df34ae5fab6cd802532594ea
name SetMeUp-C2:61:74
terminal-access
clock timezone none 00 00
rf-band all
allow-new-aps
allowed-ap b4:5d:50:c2:61:74
arm
wide-bands 5ghz
80mhz-support
min-tx-power 9
max-tx-power 127
air-time-fairness-mode default-access
channel-quality-aware-arm-disable
client-aware
scanning
rf dot11g-radio-profile
max-distance 0
max-tx-power 9
min-tx-power 6
disable-arm-wids-functions off
free-channel-index 40
rf dot11a-radio-profile
max-distance 0
max-tx-power 18
min-tx-power 12
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
extended-ssid
web-server
ssl-protocol tlsv1_2
hash-mgmt-password
hash-mgmt-user admin password hash *************************************
wlan access-rule Test
utf8
index 0
rule any any match any any any permit
wlan access-rule default_wired_port_profile
index 1
wlan access-rule wired-SetMeUp
index 2
rule masterip 0.0.0.0 match tcp 80 80 permit
rule masterip 0.0.0.0 match tcp 4343 4343 permit
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule SHBI
utf8
index 3
wlan ssid-profile Test
enable
index 0
type employee
essid Test
utf8
wpa-passphrase f931b9b0a2ab2a291f1253bb8e5a9569ba9e22958c86a213
opmode wpa3-sae-aes
max-authentication-failures 0
auth-server InternalServer
rf-band all
captive-portal disable
dtim-period 1
broadcast-filter arp
blacklist
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
wlan ssid-profile SHBI
enable
index 1
type employee
essid SHBI
utf8
wpa-passphrase fdb1e0983543695cd1bbd03a7d4c6dfa1e677995404cdbac
opmode wpa3-sae-aes
rf-band all
dtim-period 1
auth-survivability cache-time-out 24
wlan captive-portal
background-color 16777215
banner-color 15329769
decoded-texts banner/terms/policy
banner-text "Welcome to Guest Network"
terms-of-use "This network is not secure and use it at your own risk."
use-policy "Please read and accept terms and conditions and then login."
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
wired-port-profile wired-SetMeUp
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-SetMeUp
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
no shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
enet0-port-profile default_wired_port_profile
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
disable
airgroupservice airplay
disable
description AirPlay
airgroupservice airprint
disable
description AirPrint
clarity
inline-sta-stats
inline-auth-stats
inline-dhcp-stats
inline-dns-stats
cluster-security
allow-low-assurance-devices
Ashley Gibbon
