Become a Member
We have a 2930M with a 2930M 4SFP+ (JL083A) module in the back. The switch is managed by central however I can't find a way of configruing the VLAN's for this module. I need to configure tagged and untagged VLAN's but can't add tagged VLAN's to ports A1 to A4 . I have tried CLI snippets but these failed.
How can this be done?
AFAIK in a UI group the module should appear as a normal port under the "Wired Management" under Port/VLAN for it to be configured.
What version are you running on the switch?
Thanks for the reply. It is running 16.06.0008. In the end we used a template group to get it working.
