Cloud Managed Networks
Aruba Central connectivity issue with Azure AD
This thread has been viewed 16 times
  • 1.  Aruba Central connectivity issue with Azure AD
    Posted Mar 31, 2023 10:29 AM
    Dear All,
    I have successfully integrated Aruba Central with Azure AD for user authentication. When trying to authenticate the SSID with Azure AD username and passwords receiving below error.
    "can't connect because the sign-in requirements for your device and the network aren't compatible"
    With using Aruba Onboarding app the authentication can be done successfully. But are there any workaround for using only SSID to authenticate using AD UN & PW without using Aruba Onboarding app ?
    Thank You
  • 2.  RE: Aruba Central connectivity issue with Azure AD
    Posted Apr 01, 2023 02:39 PM
    Edited by ulises.cazares Apr 02, 2023 10:12 AM
    Hi, It's my understanding that you can't use AD UN and PW since Azure AD expects t o authenticate using certificates and that's what the Aruba Onboarding app helps you with.
    I hope this helps
