  • 1.  Aruba Central-Managed Mobility Gateway
    Posted Mar 14, 2024 04:55 PM
    Edited by mvanoverbeek Mar 14, 2024 05:08 PM
    I always try to do my due diligence but so far haven't been able to find reasons why a Mobility Gateway is necessary if you manage it through Aruba Central
    It seems that all security related features can be done on the access-points itself while all roaming related services are in Aruba Central
    The only compelling reason I found in this document Segmentation Design | Validated Solution Guide (arubanetworks.com)
    It mentions if you have more than 500 APs or 1000 clients you need to use a Gateway. But what about segmentation in general, can't that be done on an AP in a small environment?
    I am probably overlooking something, but it would be great if someone knows or can point me to some documentation that shows the compelling reasons to use the Gateway as a mobility gateway in Aruba Central.
    Thank in advance
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: Aruba Central-Managed Mobility Gateway
    Posted Mar 14, 2024 07:31 PM
    I'll refer you to https://www.arubanetworks.com/techdocs/aos/aos10/design/gateway/
    Carson Hulcher, ACEX#110
  • 3.  RE: Aruba Central-Managed Mobility Gateway
    Posted Mar 15, 2024 09:21 AM
    I obviously need a course into "how to navigate" the Aruba documentation! This is exactly the missing puzzle piece, thanks for sharing
  • 4.  RE: Aruba Central-Managed Mobility Gateway
    Posted Mar 15, 2024 10:44 AM
    New addition to the documentation portfolio, hasn't been linked to the usual locations yet.  So think of that as a sneak peek.
  • 5.  RE: Aruba Central-Managed Mobility Gateway
    Posted Mar 15, 2024 04:35 PM
    Thanks Carson, thanks for the sneak peak, however, I still think I need a course on how to navigate Aruba Documentation thusfar I google my way to the Aruba docs :)
