Cloud Managed Networks
  • 1.  Aruba Central Showing APs Offline in Floor Plan
    Posted Sep 07, 2023 08:56 AM
    When we look at the number of devices online under sites > devices we have 20, however, when we look at overview and floorplan it is showing 18/2.
    Why is the floor plan showing we have 2 APs offline?
    Thanks you, Paul.
  • 2.  RE: Aruba Central Showing APs Offline in Floor Plan
    Posted Sep 07, 2023 08:57 AM
    APs that are offline are either switched off, in a reboot, or can't connect to Aruba Central.
    It may also be that there is no subscription applied in Central for those APs.
  • 3.  RE: Aruba Central Showing APs Offline in Floor Plan
    Posted Sep 07, 2023 09:04 AM
    All APs are showing online int he device view, but when you click on the Floor Plan there are 3 APs offline.
    That is the issue.
  • 4.  RE: Aruba Central Showing APs Offline in Floor Plan
    Posted Sep 07, 2023 10:23 AM
    Could it be that you renamed those APs or so?
    I would remove them from the floorplan and re-add in to see if that solves it. If not, best to open a TAC case.
