.... and is LLDP enabled on the APs?
Central may leverage the LLDP transmits from the switch if the AP at least receives LLDP. But having LLDP transmit&receive enabled on both AP and switch would be the best as you can see the AP names as well on your switch.
Original Message:
Sent: Jan 05, 2023 05:10 PM
Subject: Aruba Central Site Topology without neigbour devices
is LLDP enabled on the unmanaged switches?
Original Message:
Sent: Jan 05, 2023 11:00 AM
Hi all,
I realize today that Aruba Central Site Topology tab shows my APs but does not show the switches to which the APs are connected on.
The APs are Central Managed , the switches are not Central Managed
but I remember I was able to see the AP-switch topology for example in November 2022.
Is it the same for you?
Thank you for your time
