  • 1.  Aruba Clearpass compatibility with cisco Wireless controller
    Posted Feb 10, 2022 02:36 PM
    Dear team,
    does anybody know if there exist any compatibility matrix os cisco WLC software and clearpass software? I am experiencing problems with an old controller os cisco and in the new one I am not seeing those errors.
    Could you help me, please?
    Thank you!
    tecnicos bilbao
  • 2.  RE: Aruba Clearpass compatibility with cisco Wireless controller
    Posted Feb 11, 2022 08:57 AM
    AFAIK, there is no matrix.  What errors are you seeing?
  • 3.  RE: Aruba Clearpass compatibility with cisco Wireless controller
    Posted Jul 18, 2024 09:41 AM
    Hi cjoseph,
    I need to check the compatibility between Cleaspass and Controller.
    Can you help me find reference documents?
    Thank you
  • 4.  RE: Aruba Clearpass compatibility with cisco Wireless controller
    Posted Jul 18, 2024 09:42 AM
    Hi Cjoseph,
    I need to check compatibility between Clearpass and Controller.
    Thanks you
  • 5.  RE: Aruba Clearpass compatibility with cisco Wireless controller
    Posted Jul 18, 2024 11:01 AM
  • 6.  RE: Aruba Clearpass compatibility with cisco Wireless controller
    Posted Jul 18, 2024 11:13 AM
    Sorry for the unclear information, Controller is Aruba, please help me further
  • 7.  RE: Aruba Clearpass compatibility with cisco Wireless controller
    Posted Jul 22, 2024 03:43 AM
    That depends on the architecture chosen, used features and software version, but I'm not aware of incompatible combinations of ClearPass and Aruba controllers.
    I'd recommend to work with your Aruba partner, or invest in training like Aruba Certified, where campus access is more focused on the network equipment, and the security track has more focus on ClearPass (and other security products).
    As there are many combinations (versions, architectures, models, brands) between ClearPass and your networking equipment, there is no document for each possible integration. If you understand how your controllers work and how ClearPass works, it's trivial to combine the two together. There are quite some videos on Youtube as well how to set this up, and the ClearPass documentation page is a rich source of information.
